    May 2018
    28
    Question Balance charging a lipo not to full. Is it ok to do?
    Hello,
    I have a gensace 5300 mah 65C 2S and skyrc imax b6 original charger.
    Is it ok to balance charge the lipo from storage voltage to load some amps/volts and stop before itís full?
    The reason is, I donít wish to run for a whole full hour. I wish to run only for some 20 minutes. So I can save time in charging and save time on discharging unused voltage (by running in car) to bring down to storage voltage.
    Note - I know that b6 have storage mode, but it takes so long to discharge if there so much voltage/amps left in the pack.
    Thanks.
    Feb 2002
    9,352
    it wont hurt the battery, just will make your runtime shorter.. lipos tend to keep their voltage pretty high, and stay at that same voltage until it dumps, when it dumps, it drops off fast, at lvc
    storage voltage is ~3.8 volts per cell --- 3.4-3.5 volt is the standard for longevity with lvc
    May 2018
    28
    That exactly I want.
    Yes I plan to stop running at 3.8v
    RC Champion FnFancy's Avatar
    May 2016
    Los Al California
    1,658
    Just run it from storage voltage. Then charge it back up to starage after. I do this all the time to cycle batteries
    it's alright son, I'll fix it when you break it.
    Michigan
    8,203
    Quote Originally Posted by FnFancy View Post
    Good idea for short test runs; I should go this rout but I'm so darn OCD about my lipo's I always charge them and use my P6 to bring them back to storage voltage if I don't run them down that far while in the truck.
    I've become accustom to running on a clock rather then LVD, 15 minutes on a 5200mah lipo puts me at or very close to 3.8vpc.
    May 2018
    28
    Doing so will give me just couple of rounds (before voltage drops so low). I wanted bit more than that, that why I wanted load some juice but not full.
