Results 1 to 17 of 17
    Jul 2018
    5
    Spartan Upgrades (specifically motor/esc)
    I just got my Spartan and have been using it for the weekend. I'm a fiend for upgrades, so I've already sprung for the following...
    -Full cooling system upgrade (dual pickup rudder, dual outlets, aluminum cooling jacket)
    -New Fins (Hot Racing adjustable trim tabs and turn fins)
    -Rear Splash guard (because it wasn't expensive and should look cool)
    - X442 Aluminum prop (because the S215s are impossible to find)
    Are there any more upgrades, specifically anything mechanical, that it would make sense to add? My main playground is Lake Michigan which the stock spartan handles quite well with good weather. I went with the fins to try and help gain some stability because I have had a flip or two. Any suggestions for anything else I could do would be much appreciated.
    Eastern Shore, Maryland
    4,516
    There all kinds of cheap mods that you can do to get better performance out your Spartan, but what you have mentioned above is a very good start.
    4,516
    I just happened to see this:
    1). the Hog cooling mod which consists of a HR dual port rudder and OSE aluminum jacket.
    2). the ESC cooling mod which consists of making a ESC water cooled heat sink and adding a Castle CC Cap pack.
    3). the anti grease spooge mod which consists of extending the stuffing tube.
    4). the flex cable collect mod which consists of trimming the OEM collects threads.
    5). the anti turtling mod which consists of installing two hatch posts for better hatch securing.
    6). the water seal mod which consists of adding a rear OSE splash guard and sealing the rear hatch area.
    Jul 2018
    5
    Could you give me some more information or point me in that direction on that anti turtling mod? I had that happen a couple times and would love to have a solution.
    4,516
    Yes, but just to let you know you can also tape your hatch. I like this mod, because with it battery changes are a lot easier/faster than taping.
    Jul 2018
    5
    That looks awesome! Where did you get those posts from and how are they attached?
    4,516
    The posts are nylon bolts, and they are secured by small wood screws (photo 4). The assembly itself is secured to the boat by double sided tape and a small allen head screw and nut (photo 2).
    Sep 2018
    54
    Exrteme work with spartan.... NICE AND CLEAN.... Appreciate that
    Lähetetty minun COL-L29 laitteesta Tapatalkilla
    4,516
    You are very welcome.
    Mar 2014
    Fredericksburg, VA
    73
    We need someone or some company to make these products. I'm too lazy and inexperienced to attempt it myself
    4,516
    Quote Originally Posted by TheWhiteBuffalo View Post
    Working on, experimenting, and learning isn't work, if you do it with the right frame of mind. It's playing, just as much as operating your toys is.
    Feb 2018
    Toledo Ohio...USA
    35
    another fine post my friend......
    4,516
    Thanks, it's not an easy mod to do, because everything has to be right on the money. But, it sure does work good.
    Mount Real, Canada
    648
    It is what we called a “HOBBY”
    Sharing is the best thing to do on EARTH legally.
    4,516
    As always, you're right on the money Edge.
    Dec 2019
    3
    Side hood latches
    Did you make them or buy them?
    Thanks,
    Eddie
    4,516
    I made them. You can get the brass from your (LHS), and the white nylon posts are nylon bolts cut down to size.
