Results 1 to 7 of 7
    Feb 2018
    44
    Can you charge SMC lipos on the Traxxas EZ-peak dual charger?
    Can you charge SMC lipos on the Traxxas EZ-peak dual charger? I'm thinking of getting some SMC lipos (with traxxas connectors), but want to know if I'll need a differnent charger.
    RC Qualifier Myrustlervxl's Avatar
    Dec 2016
    Ohio
    500
    If the ez peak dual charger has a balance port it will. Or i think traxxas sell an adapter for non traxxas lipo
    Sent from my SM-G930P using Tapatalk
    Good work isn't cheap, cheap work isn't good
    RC Champion FnFancy's Avatar
    May 2016
    Los Al California
    1,808
    Quote Originally Posted by GengarMan57 View Post
    No need for a different charger, as long as your getting 3s or under packs. There is little doors under the main plug that has the balance tap inside. You'll have to tell the Traxxas charger what to do as it won't automatically detect what battery your plugging in but it's simple to do. Read your manual for the correct steps.
    it's alright son, I'll fix it when you break it.
    Feb 2018
    44
    Quote Originally Posted by FnFancy View Post
    Thank you!!!
    Nov 2019
    DMV
    15
    Now how many amps do you charge the SMC 3S lipos with 6500mAh on ez peak live dual charger?
    Dec 2003
    Dekalb, IL
    2,857
    Up to 6.5A is safe. I think SMC typically suggests 1C charging with 2C capable.
    https://www.youtube.com/c/olds97lss
    RC Qualifier Acidic01's Avatar
    Jul 2018
    792
    The paper that came with smc batteries today says max 3c charge but best to be in the 1 to 2c range for best performance.
    So if 1c the size of battery is how many amps. If 2c. Then 2x the mha. So if 2c @6500mha. Would be 13amps
