Results 1 to 12 of 12
    15
    Batteries - Front or Back?
    What is the best placement of the batteries for this RC boat? Towards the front or back and why? TIA
    Jan 2018
    Mansfield Ohio
    33
    I run mine in the second slot from the front have a little chine walk but not to awful bad
    Eastern Shore, Maryland
    3,948
    I run mine 1 inch back from the front. Why? That works best for me.
    15
    Awesome. Thank you for the insight.
    May 2018
    9
    Quote Originally Posted by jjevans View Post
    i always decide about the water is calm or not. if there is both calm water and no wind u can set ur lipos to the back but better to remember using lipos at front area always safer.
    Sep 2018
    54
    Front
    Lähetetty minun COL-L29 laitteesta Tapatalkilla
    Sep 2018
    13
    I tried a few different spots, but then decided to actually find out where my CG (center of gravity) was, which is not hard. So i loaded everything as in "running" condition. Measured the boat (without overhangs such as strut/rudder and stuff), then balanced the boat to find the balance-point. The CG was less than 30% with batteries all the way front, and with my (quite big) batteries, i have the cg right about the middle of the battery-packs when they are all up front. So from first "thinking" that batteries all the way up front was frontloading it, now, i can see that the batteries all the way forward makes perfect sense for my setup. Just my 5 cents. The cg will differ a bit depending on your setup ofcourse. For me, i have a very nicely balanced Spartan now that runs like a beaute, and this is ofcourse also about setting your trim and strut to suit your setup aswell. Unfortunately i dont remember offhand exactly what my CG was. Just that it was about "normal". I might add i have an iphone/gps infront of the motor aswell in my setup.
    Quote Originally Posted by Speeder View Post
    Front
    Why have one Spartan when you can have two?
    Sep 2018
    54
    I keep behind and correct the move with trim tabs..
    Sep 2018
    13
    Yes, but you wan't a minimal "correction" with the trimtabs, as they will produce drag (go slower). So they should help with stability, but the less they have to interfere, the better. Ideally.
    Sep 2018
    54
    Have to try... Immietedly
    Sep 2018
    13
    Here's a little vid of my spart from this weekend (just the date on the cam i forgot to set/remove). https://youtu.be/uxYbWmquh74?t=107 Next summer i will run it closer to you, on the Aaland Islands.
    Sep 2018
    54
