Results 1 to 21 of 21
    Jan 2018
    442
    Tires for my Bandit?
    Hey, I need new tires for my Bandit. I have tried Proline Dirt Hawgs, and Traxxas Anacondas and both of those wore out completely in 2 weeks. Wondering if anyone could recommend decent tires for on-road that will last a lot longer.
    Apr 2017
    205
    Proline Dirt Hawgs are made for dirt, not on road that's why they wore out fast, I have heard good things about duratrax banditos
    Jul 2018
    North kingstown ri
    166
    Get 17mm hex adapters and run the xo1 tire
    Sent from my LGLS991 using Tapatalk
    Rotterdam, Netherlands
    8,617
    JConcepts GLocs are great tires that don't wear nearly as fast as Anacondas.
    Jan 2018
    442
    BrickitSAM I have heard about Banditos. They sound pretty good. Are there 2.2 Banditos?
    bent hinge pin, I really want to keep this a Bandit. Not really interested in putting massive hexes and tires. I already have a Rustler for that.
    Jul 2018
    North kingstown ri
    166
    Quote Originally Posted by RC_N3RD View Post
    The kumo tire that comes stock on the slash xl5 was a long wearing semi roadable tire
    Jul 2018
    North kingstown ri
    166
    12e
    Jan 2018
    442
    Yeah, not really into using slash tires. I really want to keep it a true Bandit with true 2.2" wheels and tires. I also want to avoid hexes, because they strip out unless you go aluminum which just costs more. The built in hexes are great for durability!
    Apr 2017
    205
    2.2's
    https://www.amazon.com/Duratrax-DTXC...ax+bandito+2.2
    https://www.amazon.com/Duratrax-C510...ax+bandito+2.2
    I have run plastic hexes on my bandit for a few months now with brushless, they will not strip if you keep the wheel nuts tightened down all the way, it's only if you let them back off you have problems.
    Jan 2018
    442
    Yeah, the problems definitely begin with loose wheels. Still though, even if a wheels comes loose on the Bandit, the hexes wont strip since it doesn't have any.
    RC Qualifier Trentbaby65's Avatar
    Feb 2017
    433
    No hexes? Please explain.
    20,472
    True Bandit wheels are pin-drive. Like the crosspin that the hexes slip over/snap onto.
    Alt-248 on the number pad =
    Jan 2018
    442
    The problem with the hexes is that if the wheels come loose. They can strip. What happens is sometimes the wheel nuts will come loose, and if that happens the wheels will move away from the hexes, and they will slip, which causes both the hex and the wheel to round out. If it rounds out too much, the expensive wheels and tires can be rendered completely useless.
    You can combat the problem a little bit by upgrading to aluminum hexes, or in my Rustler's case, the steel ones that came with my MIP X-duties. You could also threadlock the wheel nut, but that would get annoying if you had to do it often. I find that just not having wheel hexes seems to just increase the lifespan of the wheels drastically.
    Nov 2018
    I have a Traxxas Bandit, and I was looking at this and I think I'm going to buy Duratrax Banditos, but I am confused because the links all say that the tires & wheels are for the front. Is that still going to work?
    Where can I find aluminum hex adapters for my Bandit because having aluminum hexes would be nice to avoid stripping and it would let me use my old rc cars wheels.
    Jan 2018
    442
    Wow, 20 days ago. Sorry for late response. The front offset wheels will work fine, that's what I'm using. For hex adapters get some strc aluminum adapters for the Rustler and Stampede. Rear ones should fit straight on the rear Bandit axle and work fine.
    Oct 2018
    Southern CA
    58
    I bought some used proline primes. They don't get the best grip on road, but they seem to last a long time. I mostly use them for drifting in the garage. I also need some durable tires ,so I was looking at the 2.2 banditos...
    Jan 2018
    442
    How long have you had the primes?
    Oct 2018
    Southern CA
    58
    About a month and a half, but still going.
    Jan 2018
    442
    Wait, I found them! This could be the one remaining tire to save my Bandit... which would be same setup as Rustler but 2.2". Eh, kinda defeats the purpose of keeping Rustler and Bandit two different vehicles but I might try it.
    https://www.ebay.com/itm/Pro-Line-Trencher-T-2-2-All-Terrain-Truck-Tires-2-10121-00/292141316652?hash=item4404faba2c:g:tYUAAOSwa3BbZE4 G:rk:27f:0
    Oct 2018
    Southern CA
    58
    Do you guys know if I could put a 2.8 bandito on my bandit vxl with no modifications???
    Jan 2018
    442
    You'd have to put a hex adapter but that's about it.
