Page 2 of 2 FirstFirst 12
Results 41 to 70 of 70
  1. #41
    Sep 2018
    5
    Have you had the stock one off? When I took it off and held it in my hand, it was pretty clear that the aluminum one would be far superior.
    Sent from my SM-G920V using Tapatalk
    Thanks - Can see the difference.
  2. #42
    Jun 2018
    23
    https://tboneracing.net/collections/2-0-e-revo
  3. #43
    Oct 2018
    Quote Originally Posted by thebignasty View Post
    Does any one know of some better axles and or inner drive cup options? These dogbones are killing me!!! Ive already had to replace the rears 3 times!!!
    https://hot-racing.com/?partnumber=ERVT288RC;c=1294
    https://www.gpmracing.com.hk/en/prod...SHLESS-86086-4
  4. #44
    Jun 2018
    23
    Upgrade 2075 servos to metal gears.
    https://traxxas.com/products/parts/2072X
  5. #45
    Jan 2019
    True track rear a arms
    Quote Originally Posted by JellyVSJam View Post
    Here is a list of all the upgraded parts Ive installed and recommend:
    1. RPM True Track Rear A Arms
    2. RPM Front A Arms
    3. Traxxas Rear Chassis Brace
    4. Hot Racing 85mm Suspension Straps (like in the posts above)
    5. Traxxas Wheelie Bar
    6. Castle Motor Shroud
    7. Traxxas Bluetooth Module
    8. Traxxas Red Aluminum Push Rods
    9. Traxxas Rear Springs (Blue) & Front Springs (Silver)
    10. Traxxas 54T, 42T Metal Spur Gear
    11. Traxxas 20T Pinion Gear
    12. Savox SW1210-SG(replaces the stock dual servos) will also need an 3-4 extender to reach receiver
    13. Traxxas Heavy Duty Servo Saver
    14. Traxxas Black Chrome Front and Rear Bumpers
    15. Metal Skid Plates (bought on eBay, unbranded)
    16. LED Lights for the Front and Rear
    17. Traxxas Red Aluminum Toe Links
    How did you get the true track rear a arms. I have them and the bearings will not fit in the stock drive shafts. I'm sorry for the newbie question. I've measured the inner and outer diameters of the stock bearings along with the bearings that came with the kit and they are off. The stock bearings won't fit into the axle carriers. Please help.
  6. #46
    Apr 2019
    3
    2. RPM Front A Arms
    Yes, I would also like to know what you did to make the RPM True Track work with the E-Revo 2.0
  7. #47
    Apr 2019
    50
    Would you recommend Traxxas steel center shaft or the hot racing one?
    https://hot-racing.com/?partnumber=ERVT37CC;c=1294
  8. #48
    Apr 2019
    9
    Quote Originally Posted by MiStro View Post
    You are very welcome. i first saw the idea from Outsourced RC on youtube, but he used longer straps and made a spacer. the 85mm straps have been perfect without any spacer in the chassis brace.
    hi MiStro.. Just wondering if you could tell me what you mean regarding the spacer in the chassis? im about to do this upgrade and need to order the screws and stand off spacers too. Cheers
  9. #49
    Sep 2014
    179
    Hello,
    Does anyone make a new list for "must to have upgrades" for Revo 2.0? For now I just replace the servos and add some limited travel straps front and rear and order some steel skid plates.
    I have no issues regarding center driveshafts or spur gear. RPM has now both front and rear arms, maybe I will get them.
    Thanks,
    Radu
  10. #50
    Oct 2018
    Texas, by God!
    33
    The only must-haves for me were the red 2255 servo, chassis brace, and a sway bar set. I also upgraded to the steel spur gear, as my plastic one was starting to show a little wear, and I didn't want to risk it blowing out on me at the skate park.
  11. #51
    RC Champion RICK DIZZLE's Avatar
    Sierra Vista, AZ
    1,188
    What sway bar set did you find that works w the E Revo 2.0?
  12. #52
    Oct 2018
    Texas, by God!
    33
    It's a Gen1 sway bar kit, with longer screws, and some washers to keep the plastic part in the rear from bowing.
  13. #53
    May 2019
    Michigan
    142
    chassis brace, blew a rear link when I dead stopped at a playground, added 80mm straps to the back today and the wireless module cuz default 100% braking is crazy
    I also got shock rebuild kits cuz I heard extra bump stops help and I want heavier oil and springs
  14. #54
    Sep 2014
    179
    Can you setup the brake with wireless mode?
    When I try to limit the acceleration, by entering into the training mode, the brakes also changes. eg. If I set 30% acceleration as training mode it has only 30% brakes which is a lot less than I need. Have anyone this problem?
    I've installed 85mm rear straps and 85mm front straps, but need to put 80mm on the front.
    How about shocks aluminium rods? Does they worth?
  15. #55
    May 2019
    Michigan
    142
    The app let's you adjust TSM, Steering/throttle sensitivity, throttle trim, and steering/braking percentage. The only thing I have done is dial down braking from 100 to 35 percent so far. There is no adjustment/setting for reverse in the app - https://traxxas.com/products/parts/a...inkapplication
  16. #56
    May 2019
    Michigan
    142
    Quote Originally Posted by fozzy71 View Post
    I should correct this. Reducing braking in the app does affect reverse power/speed which is perfect for me cuz I run all my cars in 70/30 throttle neutral. The braking was so aggressive out of the box even on 50/50 neutral that I was front flipping if I was braking at speed.
  17. #57
    Aug 2012
    Alberta Canada
    1,203
    What are you guys using for failing shock ball ends? Its probably the only thing I'm breaking.
    Sent from my SM-N950W using Tapatalk
  18. #58
    Sep 2014
    179
    This is how I limit the travel, on the rear is same as others, but on front is a little different.
  19. #59
    May 2019
    Michigan
    142
    That is how I did my rear end after breaking a link/rod on the backend. I got an extra set of 80mm straps for the front but haven't mounted them yet as most seem to say you don't really need them up there.
  20. #60
    Jun 2017
    Ohio
    1,342
    Quote Originally Posted by Maxx_Adam View Post
    Are you talking about the rod ends or the actual ball in the rod eye? If you are talking about the actual rod end, hot racing makes Alloy ones, I bought them last year, yet to put them on. Or you can run the limiting straps.
    https://www.ebay.com/itm/Hot-Racing-...-/273593224824
  21. #61
    Sep 2014
    179
    Having an alloy rod end might help you without reducing the travel. But is a cheap and safe mod to put limiting straps and also easy.
    I did also in the front for an extra safety measurement and also to have the same maximum ride height as rear.
  22. #62
    Aug 2012
    Alberta Canada
    1,203
    Quote Originally Posted by radugns View Post
    Travel limit straps are the way to go, if I beef up the shaft ends I'll just pull the shock caps off the body. In a real offroad racing buggy it will have travel limit to protect suspension from fast extension
  23. #63
    Nov 2019
    Quote Originally Posted by jeeedbb View Post
    Has anyone installed the rear chassis brace over the existing brace?
    Yes had to shave a little off rear screw mount so body clip worked and added spacers and longer screws to the front 2 35mm or 40mm long screws as well
  24. #64
    Nov 2019
    Quote Originally Posted by Dave78 View Post
  25. #65
    Jul 2018
    336
    So clean.
    Let us know if it all works well for you.
    Guessing 85mm straps?
    My 90mm stretched or something as now I'm pulling rod ends. I only have the aluminum brace.
  26. #66
    Nov 2019
    Yes, but to do a proper job you need longer screws plus 2x M3 x5mm plastic washers and 1 M4 2mm plastic washer.
    As for Good replacement parts to the E-revo 2.0 I have replaced my servos with 2 Power HD 6-7.4V LW-25MG .
    They are drop ins.
    https://photos.app.goo.gl/oR9GeQyBCzu26g3u6
  27. #67
    Jun 2018
    23
    Quote Originally Posted by faria View Post
    They are drop ins.
    Good to know.
  28. #68
    Dec 2018
    42
    sorry for the question!
    are these rod ends for the shock absorber?
    aluminum rod end for push rod nobody produces them?
    Inviato dal mio SM-A310F utilizzando Tapatalk
  29. #69
    Oct 2018
    Tennessee
    119
    Can someone explain the use of the straps on the rear end, and why do people need them. Im going to be getting an E-Revo 2.0 soon and dont understand the use of the straps in the back end. Thanks
  30. #70
    Jul 2018
    336
    Quote Originally Posted by Rocketzx1 View Post
    https://youtu.be/MJOgcxF_D4w
    This vid shows and tells ya why. I don't use spacer on shock brace and use 85mm Straps.
