Results 1 to 2 of 2
    Aug 2018
    Tie rod screw grinding against rear differential ring
    There are 2 screws on the back of my wheelie bar that hold the rear bumper in and secure the tie rod to the chassis. On the left (driver's) side, if the screw is tightened too much it grinds the rear diff ring, which impedes the rotation of the tire. I back the screw out so it won't grind the diff but after running it for a while the screw starts to fall out and the tie rod comes loose.
    Please advise...
    Colorado
    450
    use slightly shorter screws - not kidding
