Results 1 to 13 of 13
    Dec 2017
    110
    Cool Best brushless system for rustler?
    Hope there are some good recommendations for the best systems out there
    RC Champion FnFancy's Avatar
    May 2016
    Los Al California
    1,681
    I run a castle sidewinder and 5700kv system, Uber fast, light wieght and reliable. The sv3 will thermal on 3s though.
    Sent from my XT1650 using Tapatalk
    Jul 2018
    North kingstown ri
    166
    I go hobby wing wp sc8 120 and 1/8 scale esc with fan you will never over work it i run a 2600 3660 can motor geared 50tooth spur 20tooth pinion mod 1 and it bearly breaks 120 degrees. Motors a touch heavy but with the proper sprin g setting its great
    Sent from my LGLS991 using Tapatalk
    Dec 2017
    110
    that sounds like a good system to consider.
    Jan 2018
    483
    I just use a 60amp Hobbywing esc. Most Hobbywing escs will probably be reliable. I like the Quicrun, and the Ezrun. For motor, something from castle should be plenty. I also have a motor from gear shop that works really well. My Bandit runs on some no name 3300kv motor and it hasn't failed me yet. Think most motors will work fine as long as you use it for the right application, with the right gearing. I would try not let it get over 160 degrees. I would also recommend something in the 3000s or 4000s kv range for the Rustler.
    Dec 2017
    110
    how about hobbywing sc8 or castle sidewinder 4?
    RC Champion Dcuda69's Avatar
    Jan 2015
    WI
    2,972
    The SC8 would work fine. I have one in a Slash 4x4 and have powered multiple different motors from the 3500 Traxxas to 1/8th scale stuff. Using 2s up to 4s packs. Zero issues.
    Slash 4x4 Ult 2150kv
    Rustler vxl
    Ford GT vxl
    Dec 2017
    110
    sweet! sounds great!
    Dec 2017
    110
    how about anything from castle?
    May 2014
    87
    I use a Castle SV3 with the 4600KV 1406. Thing is bad to the bone.
    May 2016
    Los Al California
    1,681
    Quote Originally Posted by massenrg4 View Post
    I'm almost the same, sv3 and 5700kv 1406. Stupid fast. Even on 2s, it's just incredibly quick.
    Mar 2017
    St. Louis, MO
    10
    I'm installing a sv3 and 5700kv 1406 in my Bandit right now. I hope it doesn't overheat on 3s.
    RC Qualifier chops1sc's Avatar
    Jan 2007
    Sumter, SC
    920
    Quote Originally Posted by Daveg711 View Post
    According to Castle you should be ok with this gearing. Although I personally would stick with 2s.
    Revo .18TM
    BL Rustler
    Stampede
    HPI Sprint 2
