Results 1 to 12 of 12
Thread: Spur Gear
    Aug 2018
    34
    Spur Gear
    So uhm, is there a better option then this? Totally stripped!
    Sent from my SM-G965F using Tapatalk
    RC Qualifier Trentbaby65's Avatar
    Feb 2017
    438
    Robinson racing products make nice hardened steel spurs. Correct gear mesh will stop that happening as well. I run a 2200kv, 4s and 2.8 Trenchers and keep plastic spurs in one piece.
    Feb 2017
    438
    No slipper shaft bearing issues?
    RC Champion Dcuda69's Avatar
    Jan 2015
    WI
    2,948
    Yep...something caused that. Bearings,motor mount ,mesh, etc. I also run 1/8th scale power on 3s and 4s and have only switched spurs twice in 3 yrs. and that was only to change tooth count. Still have the 54t original that came with my truck.
    Slash 4x4 Ult 2150kv
    Rustler vxl
    Ford GT vxl
    Aug 2018
    34
    Only thing I could see is the bearing didn't look too happy. This is factory fresh (ultimate edition) and only had two or three runs out. Last run it did get a bit wet so possibly played a part.
    Michigan
    8,203
    Quote Originally Posted by Chrizh View Post
    I've heard a few fellas say it's a good idea to go over the truck before running it out of the box.
    I can understand where this would be something most may not do with a RTR truck but sometimes things aren't set 100% from box to hard running.
    While it shouldn't be the case the spur may have been poorly adjusted from the start.
    I like the others run hardened RR gears but also have had a plastic Traxxas spur in my MT for two years now with a Castle 2650kv on 3 and 4 4s lipos.
    Water shouldn't have hurt anything.
    Aug 2018
    34
    Ok thanks guys. I've ordered a hardened one. Will strip the car down and make sure everything is good for new spur when it arrives.
    Jul 2018
    North kingstown ri
    166
    Looks like your mesh was too tight.
    I run this guy couldnt have been happyer with it got 100+3s packs on it with bashing and reverse drops i run a 18 or 20 tooth hardened pinion with it
    Sent from my LGLS991 using Tapatalk
    Feb 2010
    Indianapolis?
    14,136
    I have never used anything other than the plastic spur gear. It will hold 6s power effortlessly. The screw that holds your motor plate may have been loose. If you buy a hardened spur gear, you want to buy a hardened pinion gear. You say it got wet? The center bearing will lock up if it gets exposed to too much water. That would cause the spur to strip.
    Aug 2018
    34
    This one? I think it may have been the case here.
    Michigan
    8,203
    If your going to play in the water you definitely have to do a lot of upkeep on the bearings.
    I know a couple of my rigs are waterproof but with the exception of the crawlers I never run them in wet conditions.
    Aug 2018
    34
    Not regularly, no. But I reckon it's affected the bearings aye.
