Results 1 to 14 of 14
    RC Qualifier Iansprouse1's Avatar
    Dec 2016
    Asheville NC
    439
    cutting 2mm lexan body
    For my speed run slash, I bought one of the delta plastik Jaguar XRS bodies. It is made of 2mm lexan and im not quite sure how to cut it. I know ive seen others use this body so what did you use to cut it?
    Slash 4x4, Stampede 4x4, SCX10, Bearded Dragon
    Sep 2017
    46
    I have a 2mm Delta Plastil Peugeot 206 WRC body. First I ran the cut line with a hobby knife (just through the surface not deep). Then just start twisting from the cut. Pull and twist and it should cut nicely.
    Then do the finishibg touches with sand paper and use the hobby knife again if needed.
    Hope this helps!
    RC Champion lektro's Avatar
    Nov 2016
    Virginia Beach/ South USA !
    1,922
    2mm Is some thick stuff. I think I would go the extra effort of scoring it 2 or 3 times. Maybe even 4. On the last one you should put a bit extra pressure since the knife will follow the previous . Take your time with an exacto knife. They will get off track sometimes.
    Choose Life !!!
    Jan 2003
    nc
    2,556
    I used lexan scissors.
    slash 4x4 168mph
    youtube:philip jolley
    Dec 2016
    Asheville NC
    439
    Quote Originally Posted by phildogg View Post
    How difficult was it compared to a standard thickness body? I'm not a very strong guy and cutting normal Lexan bodies is a pain for me
    Jun 2018
    Marietta, GA
    179
    This is the first I've heard of extra thick lexan bodies. What is the standard lexan thickness?
    Dec 2016
    Asheville NC
    439
    Quote Originally Posted by sevin7 View Post
    I believe standard thickness is 1mm
    Oct 2016
    67
    i've always just used a dremel on my bodies.. cut off wheel for the main cuts, and a drum sander to clean up and get the wheel openings
    N. Idaho... Da Sticks!
    8,091
    2mm... wow! I think I would use a chain saw!
    For a body that thick, you just need a sharp exacto knife. Score the body where you want it cut, then give it a good bend away from the score and the lexan will snap. Recommend trying this on the flashing before you get close in to the body.
    Apr 2017
    205
    https://www.sears.com/craftsman-evol...FYiOaQod5DELYw
    I use these instead of lexan scissors, they are about the same price, and come in 3 different variations, left, right, and strait. They would be able to cut the 2mm lexan like butter if they can cut through iron.
    Jan 2003
    nc
    2,556
    Quote Originally Posted by Iansprouse1 View Post
    its tough to cut, but the sides are thinner than 2mm. really the back was the hardest part.
    slash 4x4 168mph
    Dec 2017
    Van. Island British Columbia
    1,125
    I use a tile cutting blade in my dremel as close as possible and then switch it out for the 1/2" or 1/4" 80 grit sanding drum in my dremel and it's fast and never had an issue yet.
    Dec 2016
    Asheville NC
    439
    Quote Originally Posted by BrickitSAM View Post
    I have a pair of those but they are not good on round things like the cutout for the tires. this was the first thing I tested.
    Dec 2016
    Asheville NC
    439
    I'm going to give the lexan scissors a try.I will test them on the extra scrap on the edges.
