Page 4 of 6 FirstFirst ... 23456 LastLast
Results 121 to 160 of 231
  1. #121
    Jun 2014
    Southern California
    7,563
    You may have to take a drill to it to open up the mounting holes on the pad just a little to get the pins to fit...
  2. #122
    Feb 2010
    Indianapolis
    14,196
    Do you happen to know what size bit I will need to make the holes a little bit bigger?
  3. #123
    Feb 2010
    Indianapolis
    14,196
    Yes. I posted the link yesterday.
    Oops! Now I see it. It is less than $3 00! I just bought one. I will show the forum how it goes together.
  4. #124
    13,527
    If I remember I'll take a picture of mine tonight. It's as simple as removing the three pads and replacing it with the brake disc.
  5. #125
    Apr 2015
    775
    I definitely want to see a picture of this.
    Sent from my LM-G710VM using Tapatalk
  6. #126
    20,527
    A few strokes with a very small rat tail file is all that is required. You could probably giter done with an X-acto blade too. You dont have to do every hole, just every other pair. So, two on, two off. I do them all anyway.
    You only need to widen the holes in the disc on their outer edge. Drilling larger holes introduces slightly more slop, hence my suggestion of the file.
    Alt-248 on the number pad =
  7. #127
    Feb 2010
    Indianapolis
    14,196
    A few strokes with a very small rat tail file is all that is required. You could probably git’er done with an X-acto blade too. You don’t have to do every hole, just every other pair. So, two on, two off. I do them all anyway.
    Sounds good! As soon as I get the part I will get to work. I believe that I may have a small file. If not they can't be too expensive. I'm a little excited about it. This build is difinately different.
  8. #128
    Jun 2014
    Southern California
    7,563
    ^What ksb51rl said.
    I actually used a drill bit because I had one that fit perfectly. I don't remember which one I used, but it barely took off any material.
    Good luck and have fun!
  9. #129
    13,527
    As promised...
    Top photo shows the hex gone. Guess I grinded more out than I remember. Second shows it fitting on the pressure plate.
  10. #130
    Apr 2015
    775
    So does this actually replace the slipper pads, and this acts like one big pad?
  11. #131
    13,527
    Yes, you can see the plate outline in the top picture. This way it provides more surface area to the slipper. I've had it this way for years and only need to occasionally remove glazing.
    When I first did this I assumed the holes would line right up. They did for the most part but needed a little opening here and there. I don't have a file but used a drill bit to remove only what was in the way so as to not introduce slop.
  12. #132
    Feb 2010
    Indianapolis
    14,196
    So you have been using that same part for years and that is all that it has worn? Wow! That is pretty good.
  13. #133
    Feb 2010
    Indianapolis
    14,196
    I have some new parts!!! Since everyone has been talking about the new a arms, I decided to pick up a set. I will say that they do have some give to them. Nowhere near as much as their RPM counterparts. They look to be a quality part. I should have them installed before Monday.
    Sent from my SM-N950U using Tapatalk
  14. #134
    Apr 2018
    Downriver,Michigan
    147
    Are those Stockers?
  15. #135
    Feb 2010
    Indianapolis
    14,196
    Quote Originally Posted by Workingstiff View Post
    Are those Stockers?
    Those a arms come stock on the new Ultimate edition Slash 4x4 and the new Rustler 4x4. They have a nice feel to them
  16. #136
    Feb 2010
    Indianapolis
    14,196
    It has been awhile since I have posted any pictures of the Traxxas CV axles. So here you are! I got pretty close so that you can get a good idea of their condition. I also took some pictures of the Hot Racing steering bellcranks. They are also doing the job well! Still absolutely no slop
  17. #137
    Apr 2015
    775
    Awesome! I've had the same Traxxas CV axles on my truck for the Last 5 Years and the only thing I've replaced are the little rubber boots once. I've had absolutely zero problems with them.
  18. #138
    Michigan
    8,203
    If I recall correctly (my memory isn't what it once was) I used a drill bit but the amount needed removing was nothing a file couldn't have handled.
    I was doing the mod with a HR Double Up; having more then six pegs made enlarging a few more (I did them all as well) holes necessary.
    I originally did it while waiting for six aluminum pads to arrive, that was about 3 years ago; the aluminum pads are still sitting in the bags.
    Definitely a worth wild mod.
    [IMG] by , on Flickr[/IMG]
  19. #139
    Feb 2010
    Indianapolis
    14,196
    I got the parts in the mail today!!! It was pretty straightforward. I see what everyone says when they say the holes are close but need to be enlarged. So I used the 2.5mm wrench to make the holes bigger. Then I used a needle nose plier arm to finish it. I have to do some adjustments but it looks good! Of course I have pictures
  20. #140
    Michigan
    8,203
    Looks good my friend; you can let that unit slip a bit more to aleve more drive line stress without worrying about it burning up.
  21. #141
    Feb 2010
    Indianapolis
    14,196
    So I did a little work to the New Ultimate edition! I put the slipper clutch in! Things are a little tight but the more I roll the truck around the more they seem to loosen up. Pictures? Of course
  22. #142
    Feb 2010
    Indianapolis
    14,196
    Took her to work as usual today. Man! That slipper clutch difinately changes the performance of the truck. I think I may need to loosen it up some. I had absolutely no problem breaking all four tires loose and getting sideways at about half throttle! I was right when I said things should loosen up after I run it. As a precaution, I put some more grease on the ring and pinion gear on the differential. Overall I am pleased with the new slipper clutch. I'm going to play with the adjustment some and see what I can do. The Traxxas CV axles had no problem accommodating the additional power being put through them. I just know that sooner or later I will be putting in an after market motor system. She is beefed up to handle it
  23. #143
    Feb 2010
    Indianapolis
    14,196
    I'm not sure if anyone has noticed. I'm moving to Indianapolis at the end of the month. So my time is short here. So I did find the time to install two of the new a arms on the rear of the truck! So far I haven't noticed any flex in the arms from sitting. They are difinately softer than the others but they have a good feel to them. I will try and install the fronts soon. I have lots of packing to do. I will say, they look good and do the job
  24. #144
    Jun 2014
    Southern California
    7,563
    Wow... Indianapolis! What is your new screen name going to be?
    Good luck with the move and hope all works out for you and your family.
  25. #145
    Feb 2010
    Indianapolis
    14,196
    Thank you, my friend! We were able to get a three bedroom, three bedroom home with a loft, hot tub and a pond built in 1999 for less than $200,000! I will still be strong on the forum. Just a change of location. My name will remain the same. El Sobrante is where I was raised
  26. #146
    Apr 2015
    775
    El Indy
  27. #147
    Apr 2018
    Downriver,Michigan
    147
    Hopefully good things are the reasons for the move
  28. #148
    Feb 2010
    Indianapolis
    14,196
    It is a good thing. My wife and I have been waiting to buy a house forever. The prices in California are unreal!!! So we were able to buy a three bedroom, three bathroom house with a loft, hot tub and pond and forrest in Indianapolis in a great neighborhood, built in 1999 for $163,000!!! We already have employment in Indianapolis so we just have to pack out stuff and move. I now see how many Slash 4x4 parts I really have!!!
  29. #149
    Dec 2018
    12
    Congratulations on the new house!
    By the way, thats a good price! over here you can't find a 3 bedroom house below $200k in any city here.
    If its in the center of the country, thats minimum of $400k for 3 bedroom house of that age.
  30. #150
    Nov 2016
    Atlanta, Georgia
    943
    That’s crazy man! I hope to make it one day. I am curious to see what system you’ll be putting into your ultimate!
  31. #151
    RC Champion RazorRC22's Avatar
    Sep 2015
    2,197
    Good luck in IN, housing prices are definitely out of control in the bay area.
    youtube.com/c/RazorRCvideos
  32. #152
    Feb 2010
    Indianapolis
    14,196
    Thank you everyone! This move is a good thing. I have been wanting to own a house for a long time. The price of homes in California is ridiculous! For a comparable house to what I own would be at least $700,000 to $2,000,000! I'm looking forward to having a yard to run my trucks in. I can see me spending a lot of time on my deck doing maintenance to them in the summertime. It is in a quiet neighborhood so I can run it up and down the street without too much worry
  33. #153
    Feb 2010
    Indianapolis
    14,196
    Well I found out why there was a grinding sound. Come to find out that the shaft was all the way into the pinion gear so it was pushing harder on the ring gear on the differential. It has gotten better the more that I drive it but I make sure to lubricate the ring gear often!
  34. #154
    Feb 2010
    Indianapolis
    14,196
    So as many of you know, I recently moved to Indianapolis. So I decided to take the newest Ultimate edition to class with me and see what kind of response I would get from the students here. Unfortunately the day I brought the truck with me it was 2 outside so we didn't have recess but the kids enjoyed the truck running on my classroom floor
  35. #155
    Jan 2019
    SF Bay Area
    691
    If you can incorporate your RCs into a "learning experience", I might suggest approaching the principal about taking the class (and RC) into the cafeteria, gym, etc. I'm other words, any large, open, indoor room. If your can turn it into a "learning experience", the principal is far more likely to approve such a request.
    Heck, you might even find other teachers wanting to use you (in a good way, of course) for helping their classes. Just imagine where things might lead to from there.
    ~ Coming to you live, from somewhere on planet Earth.
  36. #156
    Feb 2010
    Indianapolis
    14,196
    I have been trying to come up with a lesson plan that would be of use to the students and rc. If I can get it together it will be a lot of fun for everyone!
  37. #157
    RC Champion FnFancy's Avatar
    May 2016
    Los Al California
    1,658
    I got it! Final drive ratios and roll out. Teach the mathematics and pose a question with spur/pinion, ring and pinion and tire diameters. Those who get the correct answer get to drive the truck!
  38. #158
    RC Racer hammie4c's Avatar
    Jun 2016
    404 not found
    167
    Funny that you should mention this, as me and my engineering teacher are trying to start an R/C club at my school. What grade levels are your students El Sob?
  39. #159
    20,527
    If I can make a project using a simple trebuchet, Im sure you can do that!
  40. #160
    Jan 2019
    SF Bay Area
    691
    Quote Originally Posted by FnFancy View Post
    Now, that, I like...I REALLY like.
