    Aug 2018
    32
    Hobbywings brushless sensored 2200kv rating vs 1600kv rating? Which better?
    I am so confused deciding which one I should get?
    Hobbywings brushless sensored 2200kv rating or 1600kv rating? Which better for crawling? Crawling need high torque. Speed is second for me. I need torque way more than speed. Both of them run 6S Lipo.
    Which one I should get anyone?
    Thanks
    Aug 2018
    9
    This video will help you understand a little better between brushed & brushless motors along with which kv fits your needs. Plenty of good info. Check it out! https://www.youtube.com/watch?v=BcuhdkCucGA Hope this helps!
    Sent from my SM-G955U using Tapatalk
    May 2018
    37
    Will you use 4s or 6s?
    May 2018
    37
    Ahh summit. Not crawler trx4 lol.
    Aug 2018
    32
    After so much consideration, I decided to get hobbywing combo Xerun XR8 Plus 150A with motor 4274 with 2250KV sensored brushless. Able to run 6s Lipo
    My next question is
    I have upgraded the servo with dual savox SB2290SG thats able to run 7.4v.
    My question is, should I get external BEC Castle 10 AMP Peak 6s (25 max in) 4.8-9v out ? I run with 6s lipo.
    Will the ESC alone provide enough power without external BEC?*
    I prefer not to get external BEC if possible to avoide complicated setup.*
    What the advantages do I get if I decided to get external BEC?
    What I missed out if I do not get external BEC?
    Thank you.
    Aug 2018
    30
    Quote Originally Posted by 4x4offroad3457 View Post
    good link, i think i learned somehting from that info,,,,,thanx for posting that
    Sep 2013
    France
    110
    stock radio/Rx will not let you use 7.4V, so yes you need a BEC
    "souvent fauché toujours marteau !"
