    Sep 2018
    21
    1:10 brushless old version. Differential
    So i realized that the 1.0 differential is trash compared to the 2.0 differential. Is it possible to stick a 2.0 differential in a 1.0 e revo.
    RC Champion FnFancy's Avatar
    May 2016
    Los Al California
    1,658
    Quote Originally Posted by Gabe575 View Post
    you have to trim the chassis, many believe too much, making it unreliable. Shim your 1.0 diffs, run on 4s and you should be good for a while.
    Sep 2018
    21
    The back of the chassis that i have at the moment is snapped in one small piece and the rest so i could just take the piece out and put the diff in.
    Right?
    Jun 2015
    Brossard, QC
    1,211
    Quote Originally Posted by FnFancy View Post
    You can't just trim the plastic chassis.
    Just get the 2.0 chassis, bulkhead and diff. I believe you will also need new drive shafts and transmission too.
    Sent from my VTR-L09 using Tapatalk
    Dec 2003
    Dekalb, IL
    2,360
    I have bashed the snot out of my ERBEv1 running 4S and all I've done is changed the diff bearings once over the course of a year. I never ran 6S in it and I know not to land when on the throttle. I'm still running the original trans and center axles. I did replace the rear axles once, one due to breakage, the other due to wear at the yoke. I can't recall what I have my punch settings at, pretty low I think. 75% limited I believe. Castle esc's are kind of backwards, with others, the higher the number the higher the punch. With castle, the higher the percentage, the more limited the punch.
    I ran the same spur for over a year, but finally took a tooth out of it with a pebble.
    I run my stuff pretty hard.
    Expert rigging at it's best!
    Nov 2016
    Atlanta, Georgia
    943
    +1 on the center driveshaft. Pretty sure v1 and v2 share it and my v2 center drive is now only just starting to show tiny amounts of wear.
