Results 1 to 32 of 32
    Aug 2014
    Katy, Tx
    71
    XO-1 with GRP tires
    So i got some GRP tires for my xo. It looks killer. Sucks trimming so much to make them fit but it's my street car not my trophy...
    Eastern Shore, Maryland
    4,174
    Is there any difference between stock and your new ones?
    Aug 2014
    Katy, Tx
    71
    I have not had a chance to try them yet. They are much larger then the stock. I'm using EMP axles which fit really snug. Once the weather dries up i'll try them.
    RC Qualifier kzsteve's Avatar
    Jan 2018
    norcal
    282
    be curious to see how they work out . or dont
    XO-1 GUY GETTING OLDER BY THE MINUTE
    Dec 2017
    North Texas
    630
    I'd be curious to see what your speed difference is with all other things on the car remaining the same. The GRP are a bit heavy...
    They don't have the best grip, but they are steel belted and will retain their shape better versus the oem tires. These are generally accepted as "good" till 160mph. I have yet to see anyone on these tires go beyond the 100-120 range. I had a set of the 1/8 GRPs on my Slash 4x4 and they did well.
    Aug 2014
    Katy, Tx
    71
    The tires are the only upgrade on this car so far. They are the soft compound. It's been raining here for the past few weeks so i haven't had a chance to try them yet. I'm running on a smooth concrete street that is not worn out so, it has "some" grip. The street i'v been running on isn't very long so i don't think i can hit 100mph on it. With NHRA season coming to an end i'm trying to get some track time with the XO!
    Jan 2018
    norcal
    282
    interested in out come steve
    Aug 2014
    Katy, Tx
    71
    So i finally had a chance to try these GRP tires. I'm running on fresh concrete as seen in the video above. I was by myself today so i wasn't able to do any speed runs and keep an eye on traffic. But i was able to try it out and i must say these tires are awesome. On cold start on a 91f day the tires are about as slippery as the stock tires. Once i did a burnout WOW. It was night and day different. Stock tires work better when warmed up. These tires become suction cups!!! The car does wheelies on command once the tires are warmed up. They got hot to the touch and sticky as a bumper sticker. As far as how the car drives well, it's challenging. With more grip came more takeoff and overall more power. It was harder to control without the TSM enabled and 25% steering sensitivity. Once i tried it with 50% TSM and 25% steering sensitivity, it was much easier to manage. With the taller tires i expected it to launch slower but because of the added traction it picks up speed REALLY fast. Overall i am highly impressed and would recommend them to everyone. I'm using EMP axles and after breaking-in they are still snug.
    I need to find a longer and safer road.
    Dec 2017
    North Texas
    630
    You may want to add extremely thick differential fluid which should help the car track straight also.
    Aug 2014
    Katy, Tx
    71
    Quote Originally Posted by LibertyMKiii View Post
    Indeed! I'v had to do that on most of my rc's. After trying it stock, i'll be upgrading to TRA5039 500k diff oil for the front and some TRA5130 100k for the rear. I must add that this setup seems very cool BUT the factory setup is much more forgiving and easier to drive. More traction made it harder to control! 50% TSM helped that problem.
    Jan 2018
    norcal
    282
    I run a gyro on mine & it seems to work very well @ keeping it straihght
    Aug 2014
    Katy, Tx
    71
    Quote Originally Posted by kzsteve View Post
    Traxxas TSM found in the part#6533 radio is a gyro. The older Traxxas radios don't have it. I generally can drive well enough not to need it but, with this setup, i'm definitely taking advantage of it.
    So i started the diff oil change and found ALL axle screw pins loose on the diff output shafts. Glad i didn't lose any. Used blue thread lock on reassembly. The front diff was wet but definitely didn't have enough fluid in it. The rear was dry. VERY disappointed. So she's all back together and all working well. For those who haven't done this before, make sure to pay attention to the direction your ring gear is facing so as not to lockup your drive train. I really liked the design and simplicity to pull the diffs out from the back covers. I'll see about trying it today if the weather holds up and life doesn't get in the way.
    On a side not...
    I can't stress enough how sticky these tires are. My testing street is about 5 minutes away. When i tried these tires they got really hot and really sticky. I got home afterwards and set the car down on my washing machine and it has been sitting there since. When i picked it up yesterday, the tires were stuck to the washing machine. The tire texture was back to being dry normal plastic. But when they were hot it was like they were leeching some kind of sticky fluid. I'm wondering if they don't have some kind of design like a self lubricating brass bushing but rather then lubricate it gets sticky! hmmm
    Jan 2018
    norcal
    282
    thank you for the info steve
    Aug 2014
    Katy, Tx
    71
    So i got a chance to take her out today. Nice cool low 70f day. The car is much quieter now with some diff lube. It tracks so much better now while accelerating. I made a couple of passes at 89mph, 92mph and i run out of road... I need a longer road OR a DeLorean! So i really like the lube upgrade so far. I can accelerate faster and stay straight with minimal effort. On the hunt for longer road now.
    Jan 2018
    norcal
    282
    that's really good info . glad it worked out for you ...
    Dec 2017
    North Texas
    630
    Quote Originally Posted by Jupiter View Post
    I feel your pain. Im in the Dallas TX area and it is difficult to find a good road. The best ones are black top / asphalt recently paved with little traffic and no obstacles on the sides of the road. Sort of a hard combination to put together.
    -Liberty
    Jan 2018
    norcal
    282
    I have lots of places to run , but the dust on the roads makes it near impossible to get bite . my car on these roads looks like its on steroids . lot of side ways & on my top time . good for you
    Traxxas has a strict language policy. A word filter operates to change inappropriate words to *s. When you see these in your post, you MUST edit them out. ksb51rl
    Jan 2018
    norcal
    282
    OOPPSS ... did not realize
    Dec 2018
    10
    lol starts a thread about GRP tires 18 posts long, but not a single pic of them on or has ever run them.
    4,174
    I would like to see some pictures too.
    Oct 2015
    960
    Link to the EMP axles?
    Aug 2014
    Katy, Tx
    71
    The axles are from EM Performance
    https://emperformanceproducts.com/pr...wheel-adapter/
    I can't believe i forgot to post pics of the tires... sorry guys
    These pics are before i trimmed the bodies!!
    Traction is unbelievable. Once you do a burn out, the tires get real sticky. Then the car will do wheelies on command while on concrete. I haven' tried it on asphalt.
    Dec 2017
    North Texas
    630
    As long as the asphalt road is warm it will hook up great. I ran my GRPs on a 40 degree day with some cross wind (kept the tires cool) and it was like driving on a wet road. Couldnt get into the throttle at all.
    That is why there is a "speed run season"
    -Liberty
    Aug 2014
    Katy, Tx
    71
    @Liberty yea i imagine these work better on asphalt. Hope to try it this summer.
    Jan 2018
    norcal
    282
    maybe a built in traction compound
    Sep 2019
    4
    Which kind of dimension did you used
    Hello Jupiter
    Thank you very much for sharing your Information!
    Did you used the 1/5 scaled tires from GRP, because you had to cut off parts away from your body?
    Could you share the information about the exact type of GRP tires you are confident with?
    Is there an tire alternative for XO-1 (maybe 1/7) without the need to cut off body parts (would not like to destroy the diffusor)?
    You mentioned also 1/8 scaled tires, do you have pics from them on the X0-1?
    Are they too small?
    Thanks for any further Inforation.
    Jan 2018
    norcal
    282
    send me a PM ……….. I have a couple pix ………….. steve
    *** more chassis cutting than body
    Aug 2014
    Katy, Tx
    71
    Quote Originally Posted by Schlud View Post
    Hello Jupiter
    Are they too small?
    Thanks Schlud. I'm using the P3 soft compound because of the conditions where i run. What works good for me may not work good for you. My suggestion is to learn the type of surface you are running on as far as asphalt or concrete. Smooth or ruff surface? Cold or hot surface? Dusty, wet or, dry surface? High speed runs, touring or, drifting? And last but not least, driving style, are you smooth or somewhat twitchy and abrupt in your movements. All of these things combined will inform you what type of traction you are looking for. GRP does a decent job of grading their tires according to environmental conditions but it's up to you to determine those conditions. I run the GWH02-P3 on concrete in very hot temps. I do have to get them really hot to get traction out of them. Without the burn out they are slippery. This GRP flyer is good info...
    As far as cutting the chassis well it kinda sucks but if you wanna run big tires then you have to make some mods. What i did is put a tire on and checking where it would rub and CAREFULLY removed material from the chassis with my dremel tool. I suggest grinding/cutting very little at a time so as not to grind off to much. Make sure not to only have just enough tire clearance at ride height but also at full suspension travel. The body was a little easier to cut with some curved hobby scissors.
    I haven't tried any other tires so i can't comment any further.
    I would also welcome kzsteve's advice as he is very informative on this subject.
    heya steve
    Jan 2018
    norcal
    282
    pix of xo-1 front cut for 1/5 tires ………..
    rear cuts tomorrow ……….. Dremel with cutting disk
    https://github.com/kzsteve/MY-PIX/tree/kzsteve-rc-car
    Jan 2018
    norcal
    282
    obviously I misnamed the pix above , as they are rears ……….. here are the front cut outs for 1/5 tires .
    ** any questions pm me
    Oct 2015
    960
    That looks like quite a bit of work to keep them from rubbing. A Dremel is a great tool for work like that. Just think if we had to use files or hacksaws for that.
    Jan 2018
    norcal
    282
    if I had to use the old tools , it would look worse than it does . I need to go back & clean it up , but im going to replace the parts when I no longer try to go fast . new corvette body sitting on my self Dremel is a cool way to do as its not a lot of work
