    RC Racer kzsteve's Avatar
    Jan 2018
    norcal
    247
    just another problem
    how do people keep the front diff from leaking ? it doesn't seem to seal & ooze's out the bottom . tried like 3 times , same leak thanks steve
    XO-1 GUY GETTING OLDER BY THE MINUTE
    13,322
    You won't get 100% seal of a moving part and non-moving part. Make sure the seal is properly set in the recess in the cup and ring gear. You may need to use a little lube so that it does not twist when putting the output gear through it.
    Jan 2018
    norcal
    247
    it leaks where top & bottom meet . does not leak around seals etc . apparently no seal between top & bottom . thanks .. steve
    ** maybe why no oil when I took it apart
    13,322
    Are you talking on the ring gear? There is a gasket that fits between the cup and ring gear.
    If you are talking about the differential housings, no there is no oil that goes in there. Just a little grease on the pinion and ring gears.
    Jan 2018
    norcal
    247
    ok , im not good at explaining . if only grease in rear diff , I got it . the problem was between the rear & front case of the diff . taking rear cover off exposes the ring gear . thanks steve
    ** ill geter done
    Jan 2018
    norcal
    247
    after my devastating wreck (hit curb @ about 85mph) I finally have it back together . hoping to get some good runs in .
    Aug 2014
    Katy, Tx
    63
    Quote Originally Posted by kzsteve View Post
    Sorry to hear about your wreck BUT glad i'm not alone... lol
    Another rainy weekend for me. The last time i got to run the car the same happened to me with a high speed wreck. Hit the curb, flew five feet in the air and in the end i had a broken rear a-arm and more scuffs on the body and spoiler. Easy fix, bigger tires but lot's of rain.
    Hope you get some "un-eventful" good runs!!!
    Jan 2018
    norcal
    247
    thanks . I tore the left side of the suspension off . big hit , 7-8 barrel roles . my fault , so just fixed it . they are fast !
    ** my body is for speed , I have a new body for when I get done trying to go fast .
