Results 1 to 13 of 13
    Oct 2016
    Ann Arbor MI
    68
    Hesitation on take off.
    Alright. Charged up the 3s lipos that came with my X-MAXX and took it out for the first time. Right away on take off I hit the throttle and it started then stopped then took off again. It doesn’t do this every time but durning the 20 minutes I was out it did this about 8 times. One time it started and stopped 2 before it went. Any ideas here? If it matters this is the 8s MAXX running 6s
    RC Racer X-Maxx's Avatar
    Aug 2017
    149
    Quote Originally Posted by Johnny85 View Post
    Contact Traxxas, may be an esc issue.
    6s X-Maxx-Hobbywing MAX6 8s conversion
    Oct 2016
    Ann Arbor MI
    68
    I was hoping that this wouldn’t be the case.
    Apr 2016
    48
    Update the esc firmware via the Bluetooth and the problem is gone.
    Sent from my iPhone using Tapatalk Pro
    Oct 2016
    Ann Arbor MI
    68
    What do I need to buy in order to update it via Bluetooth?
    Oct 2016
    Ann Arbor MI
    68
    Went to my LHS and picked up that link today. Will update tonight and try it out again.
    Dec 2003
    Dekalb, IL
    2,513
    If it's not that, check your battery connector solder joints on the packs and on the esc. Could also be a bad pack.
    A pack that can't supply enough current will cause that kind of issue. A bad solder joint or weak cell will do it.
    Expert rigging at it's best!
    Dec 2019
    I was sort of leaning that way will re rig I mean Check it out and I will let you know. Thank you in advance wasn’t messing with Bluetooth
    Eastern Shore, Maryland
    4,174
    If you ever want to do the Bluetooth thing for an update, but you don't want to mess with it, you can ask your (LHS) to do it for you. Most (LHS) are good about doing things like that, especially if your a reasonable customer.
    Feb 2017
    UK
    568
    Firmware update will most likely fix this
    https://www.youtube.com/iftibashir
    Nov 2014
    Ludington, MI
    140
    I’d recalibrate the transmitter with the truck first, it only takes a minute to do
    Mar 2019
    3
    Yea calibrate your esc, get the bluetooth link o find I always need the darn thing all the time to switch programs to reset the controls or to enable tsm whenever you replace your receiver.
