Results 1 to 10 of 10
    RC Champion jeteffect's Avatar
    Apr 2015
    1,760
    Steering Servo for 2s and 3s - no BEC, waterproof, direct fit
    What are you guys running for a steering Servo that’s waterproof, fine to run on 2s and 3s that’s an upgrade from stock?
    I’ve heard this works but not sure for 3s?
    HS-5646WP
    Recommendations for 2s and 3s, no BEC, waterproof drop in place upgrade appreciated.
    Thanks
    Oct 2015
    124
    Just wondering why you don't want to use an external BEC?
    As for running on the stock ESC, I am a big user of the PowerHD type servo in the 20-25kg range.
    Sent from my Pixel 2 using Tapatalk
    Apr 2015
    1,760
    Quote Originally Posted by puzzleluvr100 View Post
    Thanks - with stock ESC would you recommend the Power HD 20 or 23kg no bec?
    Thanks
    Oct 2015
    124
    I use the 20kg, but I've heard the 23kg is a bit quieter.
    Apr 2015
    1,760
    On 3s also?
    Oct 2015
    124
    Doesn't really matter what voltage you run, as the ESC only puts out about 6v anyway.
    Aug 2018
    28
    I'm running a cheap metal gear waterproof servo from Amazon, it's plenty strong 23kg I think and it works great. As for the power supply both the internal bec of the esc or an after market Bec should supply a given voltage regardless of the battery.
    My YouTube channel
    https://www.youtube.com/channel/UC9c...rIucM37i_nx3aw
    Jun 2018
    Rhode Island
    47
    I have been using the Power HD WP-23KG from Amazon for 2 months now without any problems. It fit into location without any modifications, but I did need a 4" servo extension cable to connect it into the receiver. Although I read about upgrading the plastic servo horn I paid no attention to that advice. Of course, everybody was right and a month and a half later I stripped the horn and had to take the front end apart again to replace the plastic horn with an aluminum one. Save yourself some work and replace both at the same time.
    Reinhard
    Jul 2018
    East Detroit
    182
    I used a cheapo waterproof 20kg, and it runs great so far. Been underwater reliably for minutes at a time.
    DS3218 Control Angle 180 High... https://www.amazon.com/dp/B073M3X86S...*yo_pop_ma_swf
    May 2014
    978
    I've been running a savox sw1211sg. It's been great, no issues, and not running a bec either.
