Results 1 to 9 of 9
    May 2018
    54
    Help with gear mesh!!
    Installed 18t pinion today (54t S) and I set the pins in the correct spot. But it really doesnt sound right to me. Is this normal?
    https://youtu.be/O2i-4EJFRG8
    Need help urgent please!
    Sent from my SM-G965W using Tapatalk
    Mar 2016
    1,406
    yes it's normal
    with 18t pinion- best to set mesh without the pins
    fabricator
    Wyoming
    365
    I'd recommend to anyone, remove those pins and set manually.
    In all honesty they are a great idea. Just way too much difference in company's gears. Not all the same size.
    Sent from my Nexus 6P using Tapatalk
    Who needs brakes!!!!
    Aug 2009
    Amsterdam
    9
    I have tried to install the high speed config 18/46 using the pins, but like many people reported here in different threads the mesh is WAY to big ! I assume the motor stays in place with just the four motor mount screws tight enough? I’m gonna try that now.
    Wyoming
    365
    Quote Originally Posted by Mmirage View Post
    I have tried to install the high speed config 18/46 using the pins, but like many people reported here in different threads the mesh is WAY to big ! I assume the motor stays in place with just the four motor mount screws tight enough? Iím gonna try that now.
    I don't see why it won't. I don't use stock motor or mount so I can't say for sure and I don't remember what it looks like. But the 4 screws should be more than enough to hold it in place.
    Dec 2017
    Wilmington,nc
    150
    How do you set the mesh without the pins,,I don’t see any way to manually adjust it ,,unless I’m missing something,.i like the idea of setting my own mesh...thanks
    Mar 2016
    1,406
    a piece of paper between the pinion and
    spur gears then tighten motor bolts
    fabricator
    Oct 2018
    8
    how far do you tighten down on the paper?
    14,279
    No need to use a c-clamp to push the motor over to the spur. Just firmly push them together and when you pull the paper out it will look like: VVVVVVVV. You should be able to feed a strip of paper through the gears. If it rips, it is too tight. Then with the paper out study the lash and you won't need to use paper again.
