    Jul 2018
    146
    Today's episode of "what's wrong now?" - radio issues
    As some of you know I purchased a used 8s xmaxx awhile back. I've been fighting gearing issues and worn out part issues since.
    I got the gearing fixed... I think!
    Now when I drive it, it loses signal quick! Like I'm talking maybe 50 yards away or so. Sometimes if I turn the radio on and off itll pop back on. Normally I have to walk closer.
    I'm assuming its signal related because if I drive it right around me fine.
    Radio has new batteries. What else do I check? Bout to get rid of this radio system. I've never had so many problems with radio systems in my life..
    Sent from my SM-G955U using Tapatalk
    May 2016
    6
    You may start with checking the receiver, specifically the antenna wire. I was having similar symptoms as you, and traced it to the antenna wire on the receiver being partially burned. I replaced the receiver, and no more signal problems.
    13,393
    If it is not low batteries (common on nitro vehicles) or the radio then it is the antenna. I had issues with my stock radio cutting out on my Revo and had issues even after a new receiver pack. Off/on solved it and then it would randomly shut down. Found a pinch in the metal tube near the end of the antenna, thought it could be an issue and after a new tx/rx determined it was.
    Buying used typically means you are inheriting someone's headache and I wouldn't be quick to place blame on the manufacturer.
    Jul 2018
    146
    Probably going to end up getting a futaba radio set up
    Oct 2016
    4,126
    Quote Originally Posted by jake414 View Post
    I have the 3PV and have never said, I wish it did this. Itís simple, fast, reliable, and has plenty of flexibility
