    Aug 2018
    49
    Question Are these dust boot needed?
    Every time I drive, these covers pop out from under the retainers. The top one is easy to get back in, but the lower is very hard. Are these needed? I don't understand why they always pop off...every single time. Short of driving better, what are my options?
    RC Champion FnFancy's Avatar
    May 2016
    Los Al California
    1,658
    They keep the bearings from getting to much dirt in them. I've been known to put a drop of CA glue to hold them in place, or fix a tear for that matter. If you don't run them just be sure to dust out the bearings after your run
    Aug 2018
    49
    Quote Originally Posted by FnFancy View Post
    After a run, I generally use a paint brush to get any heavy debris off, then I use my air compressor and a air gun to blow out the rest of the dust/debris from everywhere. Hopefully that'll be sufficient. Maybe I'll try some glue and see if they hold.
    Aug 2018
    49
    Is there a brand of CA glue you've found to prefer?
    Jun 2015
    Brossard, QC
    1,211
    They keep dirt out of the pivot ball. Don't really need it if you aren't submerging or drive on wet.
    Sent from my VTR-L09 using Tapatalk
    May 2016
    Los Al California
    1,658
    Quote Originally Posted by cobrar97 View Post
    I use gorilla glue personally. Its what I use to mount switches as well.
    13,496
    They are there to keep the dirt out of the pivot ball system. If they do not get pulled out of the retainer clips they will eventually dry rot. Since they do not need to cover the entire shaft, I've pushed the small end up as close to the ball as possible to reduce the chance of getting pulled out around the clips.
    May 2016
    Los Al California
    1,658
    I just noticed I messed up and said bearings! As others stated it's the pillow balls, not bearings.
