    Sep 2017
    Austin, TX
    44
    Rocks/sand/pebbles getting stuck in spur gear
    Hi all,
    My son got a new prerunner for his 6th birthday. Truck runs great and my son loves it! super fast for what it is and very well made.
    Only issue we've had so far is that when running on hard pack gravel the truck always seems to get tiny rocks/sand/pebbles stuck in the spur gear. When this happens it makes a grinding noise as the pinion is making contact with these little bits of rock stuck in b/w the teeth of the spur gear. This can also slow the truck down and makes the motor work harder.
    So when this happens i just take the cover off the spur gear and use a knife to remove the little bits of rock (some of which can get embedded in spur gear) that are stuck in b/w the teeth.
    Anyone ever have a similar issue? Any remedy?
    Mar 2016
    831
    removing pebbles from the spur
    got old about the fourth one
    closed the ports on the pinion side
    of motor with a little e6000 silicon
    no more pebbles get through
    just get out there and play
    go Traxxas
    fabricator
    Sep 2017
    Austin, TX
    44
    Quote Originally Posted by CrazyXMAXX View Post
    go Traxxas
    Thank you sir
