Results 1 to 10 of 10
    RC Qualifier Trentbaby65's Avatar
    Feb 2017
    438
    Rear diff pinion
    Has anyone rounded out the centre of the rear diff pinion. I can now turn my slipper shaft in the pinion.
    Original pinion from 8yrs. ago with missing teeth still sits snugly on the shaft.
    The pinion I replaced it with is only 6mths. old and the centre is worn out. Not happy Jan.
    Did they change the metal quality or just bad luck?
    Feb 2017
    438
    Oh, and no binding, bearings are good and truck rolls smoothly.
    RC Champion thesmogman's Avatar
    Oct 2013
    Dublin, CA
    1,249
    Part's wear out. Did you ever grease it? ANYTHING metal to metal requires grease. And cleaning and re-greasing. Why am I responding to this?????
    Slash 4x4 Tekin RX8GenII w/Pro4 4300hd
    Feb 2017
    438
    Couldn't tell you mate. But I'm a mechanic of 35 odd yrs. and I am aware of cleanliness, wear and lubrication. Read my post again.
    Feb 2017
    438
    Guess not.
    Oct 2013
    Dublin, CA
    1,249
    Defects happen. Sorry, but I thought you were wondering why an 8yr. old part failed.... I haven't heard of one failing.
    I will tell you by design it can have loads applied to it with a front collision if you're driveshaft doesn't have enough play. Have you had to replace a driveshaft or had a front collision? But might be just a bad part.
    Feb 2017
    438
    No big crashes or front hits. Everything is in good working order. I'll get a piccy up later but I suspect this new gear is a lot softer than than the old one.
    No biggy, just surprised it happened.
    Feb 2017
    438
    Update.
    Just rounded out the centre of my second diff pinion. New gears are not as strong as old ones. 8yrs. out of original. No longer than 6mths. out of new stock.
    I am hard on my stuff. I always have been.
    Sent from my SM-J530Y using Tapatalk
    Nov 2016
    Atlanta, Georgia
    943
    I think you're doing something wrong.. nobody else has this issue. My bet is the thing it connects to is worn out.
    Feb 2017
    438
    Brand new slipper shaft. Snapped my original. Now on my second replacement gear. I have a mate who does metal analysis for mining companies. Might get him to see if the old is harder than the new.
