    Nov 2015
    62
    Connecting a ubec
    Hi I have a question regarding connection of a ubec to run a number of lights on the truck. I don't want to use the receiver to power the lights. Any ideas where is the best place to connect the ubec? I also don't fancy adding a separate lipo just for lights.
    Sent from my HUAWEI P8max using Tapatalk
    Eastern Shore, Maryland
    3,948
    Quote Originally Posted by Streetthunder View Post
    UBEC
    I know what a BEC is, but what's a UBEC?
    Nov 2015
    62
    Universal Battery Elimination Circuit (UBEC)*is a 'switch mode' DC regulator that takes the high voltage (up to 23 volts) of the main battery pack and converts it to a consistant and safe 5 or 6 volts (selectable) for your receiver and servos. A UBEC is needed if the Electronic Speed Control (ESC) being used for the motor does not have a built in Battery Elimination Circuit (BEC), or if the BEC of the ESC is inadequate to power the number and/or size of servos being used.*In this case lights. You can also get a UBEC that supports higher lipo voltage input than 23 volts.
    3,948
    Got-cha. You want the one that Castle makes. I hear nothing but good things about it.
    Nov 2015
    62
    Ok great. I have that one , bit it is where to connect it is my question.
    3,948
    It should come with directions, but I believe you connect it to the batteries. Go on YouTube. I'm sure someone did a video on it.
