    Mar 2013
    Central NJ
    227
    Highest gear ratio setup
    Hi,
    What is the highest gear ratio setup that I can do? I am using the 14T pinion. Can I go any higher?
    Spur gear is stock. Can I do anything here?
    Thanks.
    Traxxas Marshal
    Mar 2003
    Wherever the road takes me.
    37,734
    I can't see gearing it any higher, as the electronics get hot enough as it is in stock form!
    Mar 2013
    Central NJ
    227
    Previously I had a 5800kv motor with a 30 amp esc. It was running hot on 14t but fast....
    I want to get a hefty 60 amp esc that can handle a high Kv motor. I want this thing to go flying.
    This time I might go with the 2430 7200kv motor.
    I also put have a spectrum avc system to help with the steering at higher speeds. Without it the car just goes into a spin after a certain speed.
    Jul 2018
    13
    What did you have to do to set up the spectrum avc?
    Quote Originally Posted by MiniElmo View Post
    Sent from my SM-G920V using Tapatalk
    Mar 2013
    Central NJ
    227
    Here is a quick video
    https://youtu.be/DVURZK1rs0s
    Jan 2019
    18
    Did you have to mod the chassis to get the motor in there?
