    Mar 2013
    Central NJ
    227
    Changing power distribution to more in front
    Hey
    Iím planning on getting a rustler 4x4 later. But I wanted to ask if it is possible to tweek the powertrain so there is more power going to the front wheels than the rear wheels.
    Apr 2002
    new york
    1,892
    yes you can install the center diff for the traxxas slash 4x4.
    PROJECT BAJA PEDE
    Mar 2013
    Central NJ
    227
    So the center diff will prevent the car from doing wheelies? Had no idea
    Does the rustler 4x4 come with center diff kit?
    Jun 2014
    Southern California
    7,528
    No, it doesn't come with one.
    Just get the one for the Slash 4x4:
    https://traxxas.com/products/parts/6814
    Sep 2015
    2,162
    Quote Originally Posted by MiniElmo View Post
    It can -- if you run lighter center diff fluid, as soon as the front wheels unload, power will bleed off the rear tires to the front and prevent/reduce wheelies. If you run thick fluid, it won't do this (as much). It's tuneable.
    youtube.com/c/RazorRCvideos
    Jun 2014
    Southern California
    7,528
    Just remember that the center diff is generally made for running with 2S LiPos.
    You can run it with 3S, but it will get hot in there.
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,006
    In all honesty it is best to learn good throttle control instead of using a center diff to reduce wheelies. The center diff is really more for racing on high traction surfaces. When used for bashing and filled with lightweight fluid they frequently fail over time from being overworked. It can also cause driveline parts to break prematurely since with the center diff only one wheel at times will get full power and when that wheel gets traction suddenly sending a portion of power to the other wheel/wheels can be a very jarring experience. The slipper clutch is the more durable option you have.
    Sep 2006
    Good, green, Oregon!
    2,229
    It would be rad to have programmable throttle and braking curves though, and it seems that Traxxas could add this with a fairly easy upgrade on the next version of the VXL system. My original ERBE had the Castle system in it from Traxxas directly, and I had the USB PC link and their desktop app to adjust all kinds of settings. Can you do any changes like this through the app with the Bluetooth? That sure would be rad!
    Eat my road grit, liver lips! -Clark W. Griswold
