Results 1 to 8 of 8
    Feb 2018
    16
    Low Voltage Cutoff on 2.0 ESC
    My low voltage cutoff seems to be kicking in too early. It happens when I am full throttle for long bursts. If I restart the stock ESC, I still have quite a bit of drive time and power left in the SMC lipos. LVC just seems to kick in before it should.... Anyone else experience this? Any solutions? Ideas to try? Thoughts?
    Could I set the ESC off of Lipo mode and just use a Low Voltage alarm on the lipos?
    RC Champion FnFancy's Avatar
    May 2016
    Los Al California
    1,658
    If the lvc is kicking in it means the batteries voltage has dropped below the set level. Turning off and back on your esc to get it to run again is not a good idea! This truck asks a lot from batteries, what your seeing is voltage sag. What smc batteries are you using? Turning off lipo mode and running an alarm will yield the same results. What voltage is in the batteries when lvc kicks on?
    Jun 2015
    Brossard, QC
    1,211
    If it happens only when you keep full throttle, then your batteries are either done for or they don't provide enough current to sustain the draw
    Sent from my CLT-L04 using Tapatalk
    Feb 2018
    16
    Yep...full throttle only for a long punch. I suspect my SMC (which are not very old) have pooped out. The 2nd cell of each is lipo is weak on voltage and Mah during charging. I notice almost overnight I was getting about 30% less runtime out of them for no obvious reason. SMC was not of much help when contacting them. They are 8 months old with about 30 charges on them. oh well.
    Jun 2015
    Brossard, QC
    1,211
    People are losing faith in SMC here as well.
    Feb 2018
    16
    Quote Originally Posted by IllusionX View Post
    Ya, I won't buy another set of SMCs... They were great for about 25 runs...then all of a sudden, lost their punch and 30% of their capacity. They are the 7200mah ones....and I am lucky to get 5000mah out of them in any of my cars. So I know it is the lipos. Darn things cost $127 shipped.
    May 2018
    3
    Are you running 2S or 3S SMCs?
    Feb 2018
    16
    Quote Originally Posted by dan3949 View Post
    3S SMC 7200mah.
