    Sep 2008
    NewYork
    676
    A few Spartan questions ( Help Please )
    So I just ordered a 2nd hand Spartan that is new and never ran , been in the Rc game for years mostly always using land vehicles and a few in the sky. I had purchased a small but fast Atomik barbwire 2 boat around 1yr ago and really had allot of fun with it. So when I had seen a nice deal on a Spartan I grabbed it. I am wondering a few things : Do the Spartan's have self righting to flip back over when throttle is applied like my current boat ? Will a single 6s lipo be ok to run in it or will it throw the balance off ? I have a bunch of 6s lipos around and did not want to have to purchase 3s batteries. Any help , tips or info would be great and thank you all
    Dec 2017
    Van. Island British Columbia
    849
    No the Spartan does not have selfrighting.Yes you can run one 6s, just connect the type of plug +/- to the esc that your batteries run on but make sure you add the second battery to keep it balanced.
    It will add a lot more weight which will effect speed and handling but is worth the try. I'm installing two 2s batteries on each side of my M41 with a water cooling bladder between each set to help with heat from the batteries.
    I'm in the same position where I have 8 5000mah 2s batteries and want a longer run time without purchasing a higher mah battery and it is a lot heavier but I haven't had time to run it yet.
    You never know until you try.
    Sep 2008
    NewYork
    676
    Ty for the info. That kind of stinks , guess I may have to keep my other boat now as a rescue boat. Also I would not want to run another battery not connected so I may as well get some lower mah 6s and 4s to run together at once. What mah size do people usually run in these ?
    Dec 2017
    849
    With the 5000 mah 2-2s's (4s total) I get about 8-10 min. at mostly full speed and another 8 or so min. at 50% power. So with stock setup my max is (34mph) on 2-2s batt's or (50+) on 2-3s batt's.
    I make sure I don't use batteries with under a 50c rating because of puffing issues in the past (not saying you can't use a lower c rating I just choose not to).
    I set my cutoff voltage at 14.4 (4s) with the telemetry so I don't end up over discharging and have lots to get back to shore.
    So I would say nothing under 5000 mah min. 50c.
    I hope this helps.
    Sep 2018
    54
    My opinion is 8400mah 3s 25c traxxas batteries.... Runtime over 16min....littlebit heavy but....
    Lähetetty minun COL-L29 laitteesta Tapatalkilla
    Sep 2008
    NewYork
    676
    Speeder what in is going on in this pic ? Do you run your batteries outside of the boat like that ? Is that a charger up front? I don't quite get it . What I am most likely going to do is run 2 6s lipos inside and wire the esc to handle it since most of my Rc land vehicles run on 6s I can use them for both.
    Eastern Shore, Maryland
    4,129
    Quote Originally Posted by justpassedu View Post
    Speeder what in G-d's name is going on in this pic ? Do you run your batteries outside of the boat like that ? Is that a charger up front? I don't quite get it . What I am most likely going to do is run 2 6s lipos inside and wire the esc to handle it since most of my Rc land vehicles run on 6s I can use them for both.
    (LOL) I think that's the way he transports it.
    Sep 2018
    54
    No.... Just getting out double batteries.... One set inside already
    4,129
    I like your canopy fasteners. That's a terrific idea. I did mine this way.
    I might have to give your way a try when I replace my hull with a custom painted one.
