Results 1 to 9 of 9
    Sep 2018
    33
    destroyed the central gears
    today I destroyed the transmission gears (those which are close to the central diffferential) I thought the weakest elements would have been the plastic gear (the one close to the motor pinion).
    any idea on how to prevent this to happen again?
    Inviato dal mio SM-G960F utilizzando Tapatalk
    RC Champion FnFancy's Avatar
    May 2016
    Los Al California
    1,831
    Holy broken gears batman! I think you are the very first to shred a transmission in one of these. Your theory of the plastic spur being the weak point is spot on, which leads me to believe there is an issue somewhere. Inspect your housing, when my chassis broke it cracked the transmission housing, which could be creating some flex. That's kinda all I got right now, let me ponder on it some more.
    RC Champion nickruger's Avatar
    Jun 2017
    Ohio
    1,357
    Did you mess with your gear mesh recently or possibly a hard enough crash or landing that your motor mount loosened up? I'm wondering what happened first, that stripped spur, or the stripped tranny gear, kinda like the chicken or the egg. I know if a spur locks up it's not good. The only time it happened to me I ended up with a stripped hardened spur and pinion and a broken motor shaft. Could of been worse, well more expensive atleast.
    Sep 2018
    33
    So I double checked everything and have no evidence of what could have caused it. My theory is that the huge jumps I kept making recently made the chassis bend at each landing (which is expected to do). The chassis bending must have compressed the gears one against each other generating some pressure. The little corner in the pinion you see at the center of the photo must have popped out and eventually ended up within the teeth causing the carnage. This is the only explanation I have to the fact that no plastic part got broken first.
    Jul 2018
    91
    WOOOOOOW!!!!!! That's insane!!! Those are some heavy duty thick gears. Really surprised to see that.
    Nov 2019
    144
    You aren't alone
    Sent from my SM-G950U1 using Tapatalk
    RC Champion RICK DIZZLE's Avatar
    Sierra Vista, AZ
    1,416
    Holy.....cow! That is crazy! I've been around RC for a good while and never have seen transmissions destroyed like that.
    Jul 2019
    46
    Did you guys find balls from the bearings loose in there? In my case the center idler gear bearings were shot, and they spilled their balls, leading to mayhem and other gear breakage. Not at the same time, but maybe a month earlier I had a stock motor seize up on my while driving wide open at 50 Mph. It put the truck into 1000 cartwheels, destroyed the spur gear and wrecked a differential... And I wonder if it maybe did a little damage to the tranny bearings that showed up later.
    Nov 2019
    144
    Quote Originally Posted by Infinity View Post
    The bearings looked fine in my transmission. But then again the gears seemed fine until they exploded. So now I have something else to look out for now.
