Thread: Taller tires...
    Dec 2015
    76
    Taller tires...
    I have the proline beadlock wheels and was wondering if there were taller tires that will fit my wheels? I want a little taller tire to get a some more ground clearance...
    Thanks
    RC Qualifier MAC FAB's Avatar
    Apr 2014
    So Cal
    725
    Axial KR2s off the TT, Baja Rey tires or AE DB8 General Grabbers, 4-3/4" tall. You'll have to deal with body rub issues. If you are feeling creative, crawler 1.9 tires would require cutting the inner diameter closer to the 3.0 i.d., those are 4-3/4" tall for the most part as well. Getting the beads to hold may be another story with the PLs.
    Dec 2015
    76
    Ok, I appreciate it!
    Feb 2010
    Indianapolis?
    13,849
    Actually I have a set of tires from rc4wd.com that are a true 2.2/3.0 tire that are quite a bit taller than the stock set. I believe that they are the Mickey Thompson Baja Claw.
    Aug 2015
    332
    Whatever tires you get will have to work with the pro-line bead style.
    Sent from my VS996 using Tapatalk
    Aug 2015
    332
    Pro-line 10134 tires are the tallest tires i have in a SCT size. They're about 4 7/8" tall.
