Results 1 to 20 of 20
    Jul 2018
    171
    Max gear sizes? 2200kv ,5mm bore
    Installing all my goodies. Got a 5mm bore 22t pinion and it wont fit on the spur. I think it is the stock spur gear.
    What's the max gears? I dont want to spend 9 bucks a pop and buy gears that wont fit.
    Sent from my SM-G955U using Tapatalk
    Feb 2018
    574
    Quote Originally Posted by jake414 View Post
    I fit a 21/54 in there. They were Robinson racing gears.
    Jul 2018
    171
    Quote Originally Posted by ati View Post
    Maybe I need to go down 1 tooth. My issue is the mount isnt big enough.
    Feb 2018
    574
    The motor mount?
    Your saying that the pinion hits the motor mount?
    Jul 2018
    171
    The motor mount?
    No, where the bolt goes into the mount for the mesh adjustment. It is maxed out, but the mesh is too tight.
    Dec 2017
    North Texas
    627
    I had ran e-revo spur a 46T Part TRA6447 at one point. It gives you some extra room.
    -Liberty
    Jul 2018
    171
    I got 22/52 in it now. Think it will work.
    I cant see the gear mesh to adjust it correctly. Am I missin something
    Jul 2018
    171
    Are these the proline powerstroke shocks?
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,134
    I don't use over 20T pinions. So when I want to go higher I start to reduce the spur from 54T to either 52T or 50T. Reducing the spurs teeth does the same effects to final drive gear ratio be it slightly less per tooth.
    I can't stress this enough. Check temps often after gear changes or you will burn up either the ESC or the Motor.
    Jun 2014
    Southern California
    7,577
    In Mod1 I have a 24 or 25T pinion (I can’t remember which off hand) with a 31T spur...
    Indianapolis
    14,216
    Those shocks are so much better than Pro-Line shocks in my opinion. I have run the stock Ultra shocks, Pro-Line Power Strokes and the Traxxas Big Bores. Based on my experience, the Traxxas GTR shocks are head and shoulders above the rest
    Jul 2018
    171
    So these are gtr? I need a tougher spring rate now
    Oct 2016
    4,284
    You may want to look into Revo springs then.
    Difference is clear
    Jul 2018
    171
    Difference is clear
    These are the gtr??
    Nov 2016
    Atlanta, Georgia
    943
    +1 on the 25/31 gearing. I actually ran the same to break 100.
    RC Qualifier Iansprouse1's Avatar
    Dec 2016
    Asheville NC
    441
    These are the gtr??
    They are.
    Slash 4x4, Stampede 4x4, SCX10, Bearded Dragon
    Jul 2018
    171
    Quote Originally Posted by Peeeenuuutt View Post
    I'm not looking to break speed records yet. I wanna gear it for like 70 right now. Currently at 22/52. I can still go down to 46t right?
    Apr 2018
    956
    Try a 50 tooth spur. Should be plenty of speed with a 22 pinion.
    Jun 2014
    Southern California
    7,577
    Jul 2018
    171
    Your post says that it was wet short grass? Has to have been losing traction?
    Either way, I noticed my truck not running as fast. Brought it back in, slipper clutch SMOKING. So need to upgrade that.
    Oh... is that the JConcepts body? I think that's the one I want
