    ProcDestryr
    Guest
    Bent Drive Shaft Out of the Box
    Hello. This is my first post...and It's been a while since I've messed with RC trucks, but decided to re-enter with the Rustler 4x4. Out of the box, the plastic drive shaft is bowed, not straight, and is very noticeable when it's spinning (e.g, rolling it across the floor, observing as the DS wobbles side to side). Is this to be expected from plastic? And I must upgrade it to have it working properly?
    I have the brushed version, for now.
    Thank you in advance.
    ProcDestryr
    Guest
    I was able to bend it straight(er). I guess I'll upgrade it.
    RC Qualifier Myrustlervxl's Avatar
    Dec 2016
    Ohio
    500
    Email traxxas and have them send you a new one.
    Sent from my SM-G930P using Tapatalk
    Good work isn't cheap, cheap work isn't good
    Sep 2016
    Los Angeles, CA
    46
    My brushed Rustler 4x4 had the same issue. Changed it to the aluminum one already. Need to buy the splined bullet adaptor for the front diff as well. Working great so far.
    Peace, J.J.
    ProcDestryr
    Guest
    @J.J
    Is this what ur referring to: https://www.amazon.com/Traxxas-6856X.../dp/B004QJJNQ8
    I straightened it fine. Will do till i can replace.
    20,527
    Quote Originally Posted by ProcDestryr View Post
    @J.J
    I think you posted the wrong link.
    Alt-248 on the number pad =
