Results 1 to 29 of 29
    Nov 2018
    24
    ZacMaster’s Build Thread
    Hello, everyone. New guy here. Thanks for all the awesome ideas on how to make my build better.
    Bought a 1/16 E-Revo last weekend, and I’m already modding. What a blast.
    First couple pictures are me figuring out what kind of shoes to put on.
    For some reason I like these Summit tires. I think I’ll buy some.
    Nov 2018
    24
    Since most of our bashing is going to be inside (young kids) and since I ordered the black Geode beadlock wheels, Canyon AT, foam inserts, I decided to gear it way down. I looked in the manual and bought the gear combo that would be highest.
    So, here’s my HR pinion (18T) and spur gear (55T) purchases.
    I ordered a 53T too, but won’t use it.
    Pulling apart the motor...
    Old 50T spur...
    New 55T HR spur.
    Love the change, tons of torque now.
    Wheels next...
    20,527
    Did you flip the transmission gears too?
    Alt-248 on the number pad = °
    Nov 2018
    24
    Never heard of that. I’ll have to do a search...
    20,527
    Nov 2018
    24
    I won’t admit how many hours of late night YouTubing it took me to find that.
    Thanks for the heads up, looks like a good way to make this an indoor basher.
    20,527
    Quote Originally Posted by ZacMaster View Post
    It’s a good way to slow it down while still using close to stock spur and pinion combinations. I did this to my mini-Summit and found it worthwhile until I sold it.
    Nov 2018
    24
    Wheels and tires showed up. These are the black Geode beadlock wheels, Canyon AT tires, with foam inserts. Straight from the summit area of the traxxas web store.
    Here’s a shot of the stock tires with the new summit tires for comparison.
    Side shot for comparison.
    Rear shot for comparison.
    Top shot for comparison.
    And finally with all four complete.
    Drives great, but these are a TINY bit bigger than perfect (aesthetically), but far closer to my views of an appropriate wheel size compared to the stock tires.
    New body and paint next...
    Nov 2018
    24
    Tonight, I did a few things. First, plastidipped a clear body purchased from LHS.
    No before pictures, but here are some during pictures and after pictures.
    You can see my masking. I did the front, rear, and two side windows. Masked matching shapes on the inside, too. (Plastidipped the inside for protection.)
    On the chassis...
    Another angle.
    Nov 2018
    24
    I tried the transmission flip tonight, then immediately undid it. Too much slop in neutral. (Would roll forward and back an inch or so before engaging the gears.) Maybe I put something together wrong, but when I undid it, it was all right again.
    Anyway, here are the pictures.
    Before swap...
    Then after swap...
    Putting everything back together...
    I had to remove the center cover from the bottom to line up the driveshafts with the output shaft of the transmission.
    Then, I used the lighter trick to permanently bend the stock antenna tube forward, then right across the front of the front body mount supports.
    Not my best work, but under the body, fits great.
    20,527
    I don’t think you did anything wrong with the flip. If I recall correctly, there was quite a bit of slack? free play? in the driveline.
    Nov 2018
    24
    I’m still happy having undid the transmission flip.
    Today at the LHS, I took advantage of the $100 upgrade to brushless...
    Chassis without motor...
    Smaller 380 motor mount...
    Smaller 380 gear cover.
    Smaller motor plate...
    And a Savox 250mg...
    Side by side...
    Halfway installed...
    From the top...
    Finally, the new motor and esc installed...
    Also, I bought a black antenna tube and redid my lighter trick permanent bending. Much better.
    Another angle. Looks nice and clean now.
    Still want a new, slightly bigger wing.
    Nov 2018
    24
    The parallel battery connector showed up yesterday.
    Plenty of runtime now for me and the kid to drive around the basement...
    Nov 2018
    24
    My Traxxas toe links showed up! (But not the pushrods yet.)
    Here they are next to one of the stock links.
    One of the rear links changed for comparison.
    And both rears changed.
    After changing the fronts.
    Finally, a tackle box as a parts storage container.
    Nov 2018
    24
    Last night, I replaced the rocker bushings with rocker bearings.
    After replacing one:
    And both done:
    I can absolutely tell a difference in how smooth the rockers operate.
    Next, steel hallow balls...
    Nov 2018
    24
    Also, I managed to replace the bushings on the Servo saver with 5114 Ball bearings, (5x8x2.5mm).
    Nov 2018
    24
    Lastly, my aluminum toe links showed up.
    The fronts replaced:
    And the rears:
    Nov 2018
    24
    My Losi Mini 8ight Wing arrived tonight. I did a ton of research and picked it as a close replica of the stock wing, but a little more appropriately sized for the look.
    The holes do not exactly line up, but they were close enough to get it bolted in.
    Nov 2018
    24
    I wanted some on-road/indoor tires, so I bought some 2.8 anacondas today, but apparently there are two different kinds (one for the nitros and one for the electrics). Different offsets.
    It appears the smaller offsets won’t work with the steering geometry, but I threw the bigger offset ones on the rear for comparison.
    Whoa. Bigger than my summit canyon ATs.
    They look cool, but I think they are too big.
    So I may downgrade to the 2.2 anacondas, or maybe try the dirt hawgs like this guy:
    Nov 2018
    24
    Also, my summit front and rear bumpers showed up.
    Might be fun to have some lights, so this was the easiest way to body-mount them.
    Nov 2018
    24
    Lastly, my 12T HR pinion showed up:
    Now I’m running 12T, 55T.
    Nicely geared for 99% basement bashing with my toddler and his 1/28 ECX buggy.
    Nov 2018
    24
    Today, I got a second servo installed. Yes, I know the single savox is enough. But I REALLY like symmetry.
    Not hooked up yet. I bought the kit with the arm in it, but you can’t have two non-adjustable arms. Servos fight. I’ll have to make one out of some shock ends. But I’ll need new shocks first.
    Nov 2018
    24
    Next, some steel driveshafts from HR and center shafts from Traxxas.
    Nov 2018
    24
    A ton of goodies showed up today.
    Yes, I know some of this is bling instead of functional upgrades.
    Speaking of functional, purple summit shocks instead of black revo shocks in back. (Blue summit shocks for the front still in the mail, but I did put the black shocks in front.)
    Red rockers, too.
    New front skid plate and servo guards.
    And red knuckles!
    And the extended rear a arms. I’ve laid the bottom and top extended on top of the stock so you can see the 10mm extension (right is aft).
    Left side new (extended aft, right side stock.
    With the rear knuckles and red wing mount installed.
    Nov 2018
    24
    Added the rear skid plate.
    Back together. Finished front shock mounts, rockers, knuckles.
    I spent about 5 minutes trying to dial in alignment, and ended up about a degree camber and 0 to slight toe in on both the front and rear wheels. Drives pretty good on the slippery garage floor. I’ll have to take it outside for a better test tomorrow.
    Nov 2018
    24
    Upgrading to dirt hawgs...
    Also, my summit blue springs for the front showed up.
    Comparison:
    All done:
    Not pictured is the 80wt shock oil for the shocks.
    Much better
    Jun 2014
    Southern California
    7,567
    All done:
    Looks great!
    Don't forget to make your adjustable steering linkages.
    Even though I run only one servo, I made one since my servo put the arm in a slightly different position.
    Have fun! :thhumbup:
    Nov 2018
    24
    Looks great!
    I have not hooked up both servos yet.
    Are those shock ends? I need to buy a set of spare shock ends to do this. Kind of want to buy it for both servos.
    Jan 2018
    3
    Zac, great build, how well does the two servos work? Do they get jittery? Do they plug into the same port on the receiver or do you use a Y connector?
    Thank you for the info,
    Josh
