Results 1 to 10 of 10
    Nov 2018
    5
    Charging question
    So I have a Thunder AC6 charger that I used on my R/C planes. I recently got a ruslter and 2 traxxas 2s lipos. I bought the traxxas ID connector charging lead with the banana connectors.
    Will this properly balance charge my Traxxas lipos? Only curious because there's no balance lead coming off the traxxas battery to connect to the balance board.
    Thanks.
    Nov 2016
    Atlanta, Georgia
    943
    Nope. You’ll have to buy an adapter to charge.
    13,328
    The Thunder does not have the balance ports built in like the iD chargers do. Since the Traxxas batteries have the balance leads integrated with the main plug you'll need a separate charging adapter.
    RC Qualifier Myrustlervxl's Avatar
    Dec 2016
    Ohio
    499
    HobbyStar Traxxas ID Charge Lead Adapter Set, 2S-4S Adapters https://www.amazon.com/dp/B076N68H4G..._CwDaCb6P7TFFT
    Sent from my SM-G930P using Tapatalk
    Good work isn't cheap, cheap work isn't good
    Nov 2018
    5
    Quote Originally Posted by Myrustlervxl View Post
    Ok so I already bought this
    Battery Charger Charging Cable: Traxxas High Current Male style to 4mm Bullet Banana Plugs https://www.amazon.com/dp/B00683ZPNK..._WSEaCbT1MA5PR
    So I also need what you posted above to plug into the end of the banana plugs?
    Thanks
    Dec 2016
    Ohio
    499
    You need a balance board
    Nov 2018
    5
    Yep, got one that came with the charger
    Dec 2016
    Ohio
    499
    https://youtu.be/E0w4gBxC4f8
    13,328
    Banana ends go to charger. iD end of battery and adapter plug together. Plug the two Traxxas ends together and then the balance plug to the board.
    Nov 2018
    5
    Got it, thanks everyone.
