Results 1 to 13 of 13
    Mar 2018
    55
    Tekno Wheel Hex on M6 Axles Depth issue
    i am sure this has been answered already but have not been able to find the answer.
    i have m6 tekno shafts on my slash and the wheel hex is too narrow, leaving a little gap inbetween the lock nut and the wheel when i tighten it down. i put washers in to help but want a more permanent solution.
    i noticed the wheel hexs from tekno are 4mm deep and the stock 4x4 are 5mm deep. anyone know of an aluminum hex that will work for the tekno axles?
    thanks!
    Mar 2018
    55
    So I have found this part on traxxas.com - crazy price for these, think I will just buy a set of hexs and then my own drill bit.
    https://traxxas.com/products/parts/6869
    Anyone know the depth/thickness (not bore) of these hex's? is it 5mm or 6mm?
    Thanks
    Sep 2007
    Virginia
    1,092
    They are 6.6mm thick. The key hole looks .5mm off center but there is ridge on the inner side of the hex.
    Never do anything half fast. Hey Ya'll, watch this
    Dec 2017
    North Texas
    550
    I think many people who are going this far with the Slash 4x4 are also going to 17mm hex conversion. Might be worth doing at this time.
    Feb 2002
    9,246
    The 1mm difference is just fine and a non issue
    Mar 2018
    55
    anyone use TKR1654X tekno hexs and if they have any play in their wheels? i have aluminum hexs on my slash that i thought were tekno but now im unsure. the 1mm is a big difference on my current wheel hexs because it is starting to groove the wheel hub between the locknut and wheel. the amount of play in my wheels is really bad.
    Jul 2013
    Northern Norway
    832
    The Tekno TKR1654X does not leave any play - a perfect hold on both stock wheels and Stampede 4x4 wheels.
    Mar 2018
    33
    Can confirm, tekno 6mm allum hexes fits gr8
    Nov 2016
    36
    I have the same problem enare vat has using the stock plastic Tekno hexes that come with the M6 kit. They are not as wide as the stock traxxas 4x4 hexes. I'm using ProLine Renegade wheels and have to add 2 of the Traxxas teflon spacers between the wheel hub and hex to get the wheel tight. Would someone please measure the width of the aluminum TKR1654X please and thank you?
    Mar 2018
    55
    so i purchased the traxxas part 6869 and did not actually have to drill out the bore. however, the set scre does not line up with the holes on the tekno axles so i cannot use the part. hopefully my lhs is ok with me returning the opened part.
    i just ordered the tekno part TKR1654X so we will see of those work.
    Mar 2018
    55
    Quote Originally Posted by enare_vta View Post
    I am happy to report that the TKR1654X fits perfectly.
    It comes with 8 washers which makes for a snug fit using 2 washers on each axle between the pin and the bearing.
    Here is a photo of the new part compared to what I was using:
    Here is a photo of the Tekno hex next to the stock slash hex.
    Nov 2016
    36
    Awesome. Thank you for the update.
    Mar 2017
    60
    Why not forget all these troubles , time , n money and just put on reverse rims , that gives u a wider wheel base , and call it good instead of worrying what's going on while your trying to enjoy yourself ? ( Just sayn )
