Results 1 to 2 of 2
    Jan 2018
    9
    LCG Chassis and aluminum bellcrank help
    I am converting my stock 2wd slash to LCG. Easy conversion, but have ran into a little problem with the new aluminum traxxas bellcrank. Are the stock bolts to long for the LCG chassis or do I need more shims. I have two on the bottom and one on the top. My question is.....do I need to go to my local hardware store and get shorter bolts or do I get more shims?
    bolts with two shims on the bottom and one on top actually started to come out of the bottom of the LCG plate.
    Nov 2018
    40
    You should be ok as I am running the Aluminum traxxas steering upgrade
