Results 1 to 4 of 4
Thread: Help
    Dec 2018
    Help
    Hey guys, brand new to gas powered r/c. Always wanted one and got the opportunity to own one but it needs a little work. So here’s my problem. I pulled the motor and cleaned it. It spins freely and with the ez starthooked up I can rotate the engine with my hand. For whatever reason when I put everything together the engine will not rotate at all. I can hear the ez start working. I don’t have fuel in it right now and I’m not sure what kind of setting the carb is at. Really need some help here. Appreciate it.
    Ps. It is a 3.3.
    12,926
    The one-way bearing between the engine and starter needs to have the lettering facing the engine. Make sure there is a washer between the back plate and the bearing as well.
    The starter also has a red dot to signify positive and needs to have the red wire hooked up to it. Looking at the back of the engine it will rotate clockwise.
    Dec 2018
    Thanks man I did have it in backwards. It’s now turning over.
    Dec 2014
    Adirondacks
    88
    start from factory carb settings Best way to know were settings are.
