Results 1 to 13 of 13
    Dec 2018
    10
    Cant get my stampede 4x4 vxl to wheelie?
    Hello,
    I recently just bought a stampede 4x4 vxl off a buddie. And i can't seem to get it to wheelie as much as it should. Every now and then it will. But seems like it should wheelie more than it does. It's running a 3s Lipo battery (not traxxas lipo though) other than thst the motor and gears and everything are stock. I wanna have fun with it but at the same time I wanna rip some wheelies.
    Apr 2018
    847
    Is the slipper clutch tight? Check it to make sure itís tight.
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,015
    Lowering the pinion(teeth) gear will increase your ability to wheelie.
    Dec 2018
    10
    And how do I do that man?
    13,498
    Remove the current pinion, replace with one that has less teeth and remesh the gears.
    Dec 2018
    10
    All fixed. Tightened up the slipper clutch and now she wheelies. its got 3s battery, and I know my buddie put aftermarket pinion gear in it.
    Dec 2018
    10
    Apr 2018
    847
    Good deal. Sounded like that was all that was wrong. On 3s it should wheelie pretty easy!!
    Dec 2018
    10
    Right. So is it common for the slipper clutch to come loose on tge pedes? Thougt i read something that said it is. Also what other upgrades can i do for speed. My buddie as a arms granite which same size as the pede and the only upgrade he has is a battery and hes faster lol
    Apr 2018
    847
    Go up in pinion size or down in spur gear size. Just watch the temps.
    Dec 2018
    10
    Ok my buddie u bought it off from put a different pinion gear in it. Just dont know what size lol
    Nov 2018
    See Above.
    115
    Quote Originally Posted by Rustler2580 View Post
    Stock is 15T pinion 54T Spur gear.
    Adjust your numbers from there, the higher up you go the faster it will go but quicker you will reach melting temps of your drive shafts, motor, everything...
    Dec 2018
    10
    Ok traversecity I'll have to tear it apart and see whar i got. Thanks for thr help,guys
