Results 1 to 12 of 12
    Nov 2018
    407
    Brushless upgrade
    So I have the old latrax sst. I want to upgrade to brushless. What are some good motors for use with stock gearing? I have a 45 amp esc btw
    Don't go brushless unless you have a lot of money and patience for this little truck. If you go brushless, you will break diff housings and diffs a lot. Keep in mind that I was running the heavy duty steel diffs, and I shredded 3 diffs. However, if you don't care about shredding diffs every run, here's your combo: Castle creations mamba micro x, venom 3s lipo, and hot racing steel CVD shafts.
    Who needs coffee when you have a 10KV+ capacitor?
    Nov 2018
    407
    Thx. The new prerunner has metal diffs. I will only run on 2s. Do you know of a milder system? And just a side question, r u a fan of kev talbot?
    If you run only 2s, the diffs might hold up, but I never had a 2s for my truck when I had it. As for Kevin Talbot, I love his channel and am going to watch one of his videos when I'm done posting this.
    Nov 2018
    407
    lol. Today i put in a 10th scale castle 4600 kv motor and ran on a 100c 6000 mah pack. I made the spur gear smooth as ice, but I hav a spare.
    Apr 2014
    8
    Here is what i have on my sst
    motor was upgraded to a Castle Creations Mamba Micro X 8200Kv motor with speed controler
    Battery is a Venom 20C 3S 1300mAh 11.1 LiPO
    Knuckles replaced with Hot Racing aluminum parts.
    Hot Racing Aluminum steering bellcrank
    Hot racing Aluminum Front and rear shock tower
    GPM Steel tie rods
    Integy composite Chassis upper plate
    Traxxas Front & rear shock tower brace
    RC Corona Metal Gear servo
    Aluminum Hex adapters
    swapped out for teton wheels
    Acer racing bearing kit
    Yeah Racing 1/10 scale 60mm shocks
    Traxxas 7579X gear set
    Hot Racing SLTN28806 steel driveshafts
    with this setup running in the back yard in the grass and down the street i havent blown a diff out. Will normally run 2-3 batteries before heading back inside.
    Jan 2019
    Just want to put this out there,
    traxxas 1/16 vxl esc drops right into latrax 1/18,
    also losi 1/18 brushless motor
    ( https://www.horizonhobby.com/1-18-xc...motor-losb9457 )
    fits perfect just the motor shaft needs about 2mm ground off the end.
    Not the cheapest but fits perfect and so far bullet proof
    Nov 2018
    407
    Thanks all... I will probably buy a gool rc system off amazon, because it is cheap, mild, and many people use it, and none of them mention that it is too much power...
    Quote Originally Posted by Luke s View Post
    If you break gears, driveshafts and more, if you get disappointed, I can say you've been warned.
    Nov 2018
    407
    Yes thank you. One major reason I want to upgrade is because the brushed system wears out fast. I will drive mildly and not too often though. Thanks all for the support.
    RC Qualifier PecosBill's Avatar
    Apr 2017
    Illinois
    353
    Sorry if this is to late, but the best system, I think, to upgrade to is a Hobbywing Quckrun system. https://www.amazon.com/Hobbywing-304...ateway&sr=8-32
    https://www.amazon.com/dp/B00JP1PPPK...NsaWNrPXRydWU=
    I run it, and use Traxxas spur and pinion, and the metal diffs, and it all works great!
    I run 2s lipo, and it goes about 30mph, when I put a 3s in, it was an over-loaded powerhouse that snapped the center driveshaft a little over half speed.
    You will need to put steel axles in, all metal servo, and a few other things.
    Doesn't need to be fancy. Just needs to run.
    Jan 2019
    23
    If I stick to 2s can I keep the stock parts? It has metal diffs.
