So I have the old latrax sst. I want to upgrade to brushless. What are some good motors for use with stock gearing? I have a 45 amp esc btw
Don't go brushless unless you have a lot of money and patience for this little truck. If you go brushless, you will break diff housings and diffs a lot. Keep in mind that I was running the heavy duty steel diffs, and I shredded 3 diffs. However, if you don't care about shredding diffs every run, here's your combo: Castle creations mamba micro x, venom 3s lipo, and hot racing steel CVD shafts.
Who needs coffee when you have a 10KV+ capacitor?
Thx. The new prerunner has metal diffs. I will only run on 2s. Do you know of a milder system? And just a side question, r u a fan of kev talbot?
If you run only 2s, the diffs might hold up, but I never had a 2s for my truck when I had it. As for Kevin Talbot, I love his channel and am going to watch one of his videos when I'm done posting this.
lol. Today i put in a 10th scale castle 4600 kv motor and ran on a 100c 6000 mah pack. I made the spur gear smooth as ice, but I hav a spare.
Here is what i have on my sst
motor was upgraded to a Castle Creations Mamba Micro X 8200Kv motor with speed controler
Battery is a Venom 20C 3S 1300mAh 11.1 LiPO
Knuckles replaced with Hot Racing aluminum parts.
Hot Racing Aluminum steering bellcrank
Hot racing Aluminum Front and rear shock tower
GPM Steel tie rods
Integy composite Chassis upper plate
Traxxas Front & rear shock tower brace
RC Corona Metal Gear servo
Aluminum Hex adapters
swapped out for teton wheels
Acer racing bearing kit
Yeah Racing 1/10 scale 60mm shocks
Traxxas 7579X gear set
Hot Racing SLTN28806 steel driveshafts
with this setup running in the back yard in the grass and down the street i havent blown a diff out. Will normally run 2-3 batteries before heading back inside.
Just want to put this out there,
traxxas 1/16 vxl esc drops right into latrax 1/18,
also losi 1/18 brushless motor
( https://www.horizonhobby.com/1-18-xc...motor-losb9457 )
fits perfect just the motor shaft needs about 2mm ground off the end.
Not the cheapest but fits perfect and so far bullet proof
Thanks all... I will probably buy a gool rc system off amazon, because it is cheap, mild, and many people use it, and none of them mention that it is too much power...
Yes thank you. One major reason I want to upgrade is because the brushed system wears out fast. I will drive mildly and not too often though. Thanks all for the support.
Sorry if this is to late, but the best system, I think, to upgrade to is a Hobbywing Quckrun system. https://www.amazon.com/Hobbywing-304...ateway&sr=8-32
https://www.amazon.com/dp/B00JP1PPPK...NsaWNrPXRydWU=
I run it, and use Traxxas spur and pinion, and the metal diffs, and it all works great!
I run 2s lipo, and it goes about 30mph, when I put a 3s in, it was an over-loaded powerhouse that snapped the center driveshaft a little over half speed.
You will need to put steel axles in, all metal servo, and a few other things.
Doesn't need to be fancy. Just needs to run.
If I stick to 2s can I keep the stock parts? It has metal diffs.
