Results 1 to 17 of 17
    Jan 2019
    44
    Urgent help please on rpm pic included
    Hi all I've done the full front set up new rpm arms I'm doing the back true track got bottom arms off but cannot find the pin for the upper arms I've youttubed etc and it's in pieces now lol does anyone have a guide or can help
    135
    The top pins can be located by removing the rear body posts
    Jan 2019
    44
    I removed this screw to try that earlier but they won't come off
    14,275
    You have to remove the three rear screws from the top of the chassis then pull the rear body mount out straight back. Though it is not critical, when you pull the pins make note of the position they were in - either top or bottom - so that your truck will perform the same after.
    Exploded views of the truck can be found through the Support button above.
    Jan 2019
    44
    I looked on the traxxas support but couldn't find it I find tons of erevo ones so I need to fully dismantle the back ? Front was so much easier pin wise
    I feel like a div I can't find a arm removal on support
    I did really well on the front as was a nice guide online
    14,275
    Click on Support above. Then in the very top search box type in 5309. You can pick any Revo as they have remained largely unchanged since 2006 when the extended chassis came out.
    Jan 2019
    44
    Oh crap I'm out my depth
    https://traxxas.com/sites/default/fi...ews_rear_0.pdf
    That has lost me I might not go true track back and not fit and leave it
    Front is repaired at least
    Jan 2019
    44
    I tried exploded this morning it just breaks it apart doesn't say how to get it off
    Apr 2018
    1,043
    All you need to do is remove the 3 screws on the back body mount, and pull the body mount off. Then the pins will be exposed at the tips. Pull them out and like said make sure you place them back into whatever hole you removed them from. There are 2 positions that they can be placed into. You want whatever one you took them out of. It’s not hard. Just takes a little bit of time and removing that back body mount.
    Jan 2019
    44
    222 I'm gonna sound a div here but which 3
    Thanks millions for helping tho
    Apr 2018
    1,043
    The 3 that hold the back body post in. As seen here
    14,275
    Quote Originally Posted by Basscrszy View Post
    The one you have undone as seen under the yellow wire in the picture. As well as the other two in the rear as seen right above where the a-arm attaches. Then pull the mount straight back out.
    Jan 2019
    44
    Thank you both so much I'm gonna start now
    I do really really apprieciate the help
    Apr 2018
    1,043
    No worries. Glad to have been of some help! Just paying it forward. Hopefully you’ll one day do the same.
    Jan 2019
    44
    Well guys as always your amazing here we go
    Jan 2019
    44
    Everything runs mint suspension wise very stable less twitchy now thanks again
    Apr 2018
    1,043
    Glad you got it sorted!! Have fun with it.
