Results 1 to 16 of 16
Thread: Ball bearings
    Jan 2019
    49
    Ball bearings
    Basic question for you guys but I'm unable to find a clear answer through searching unfortunately:
    I'm looking at buying aluminum steering blocks, caster blocks, and rear carriers. I notice that some are sold with bearings and some without.
    Question: From the factory, does my Rustler 4x4 VXL have bearings or bushings at those locations? It's a new car so if it already has bearings, I don't see a need to replace them yet. If it's bushings though, I'll drop in bearings while I'm in there. Thoughts?
    Thanks!
    Apr 2018
    1,043
    Should have bearings in all the places you mentioned. I donít think they would put bushings in an rc meant for speeds such as the rustler can attain.
    Jun 2014
    San Gabriel, California
    8,388
    Welcome back to the hobby/addiction and to the Traxxas forums!
    The stock parts that you are upgrading already have bearings in them, not bushings.
    Since your rig is new, just swap the bearings into the new parts.
    Have fun!
    14,185
    Look at the exploded view. Any part where a bushing or bearing would be will have the size and if it has "BB" behind it then it is a ball bearing. Anything designated as "PB" is a bushing.
    Jan 2019
    49
    Thanks guys. I figured they were bearings but I appreciate the confirmation. For some reason I didn’t think to look at the exploded view. Should have started there vs google... thanks again!
    RC Champion Panther6834's Avatar
    Jan 2019
    SF Bay Area
    1,037
    If your vehicle is new, you should be able to use the original bearings with the aftermarket parts...at least, I think you can.
    ~ Coming to you live, from somewhere on planet Earth.
    Feb 2019
    Hello,
    I'm new to this whole Taxxas/forum thing but here's my issue. I got distracted while driving and slid my Russtler into an electrical box and snapped the Steering Block in two. I'm now missing both bearings that were originally in there so now I'm upgrading. I have all the parts I need but when I search for the bearings I hit a road block. Traxxas website says I need 5x8x2.5mm while some guy at Traxxas said I needed a 5x11x4mm. From the videos I've watched it looks like there are two different sizes (one for the front and one size for the back of the steering block). What size do I need so I can get my rig back in the snow!?
    Jun 2014
    8,388
    Jan 2019
    SF Bay Area
    1,037
    Part numbers 5116 & 5119.
    Jun 2014
    8,388
    By the way, the 5x8x2.5 bearings are what is used in the steering bellcrank, not the steering block.
    The front steering blocks use 5x11x4 on the outside and 10x14x4 on the inside.
    The rear carriers use 2 5x11x4 on each side.
    Jul 2013
    Northern Norway
    897
    I know it was just a typo, Squeegie, but the inside bearing is 10x15x4mm.
    Feb 2019
    Tha is for that exploded view. After I wrote that I went through all my paperwork and found the same breakdown. The two bearings I needed are 5116 and 5119 5x11x4 and 10x15x4. Thanks for the help
    Jun 2014
    8,388
    Quote Originally Posted by Viking View Post
    Oops! Yes, 10x15x4 on the inner side of the steering blocks.
    Thanks for catching that!
    Jan 2019
    SF Bay Area
    1,037
    Time for some coffee, Squeegie.
    Jun 2014
    8,388
    ...or to cut down!
    Jan 2019
    SF Bay Area
    1,037
    There's a reason I call it "wake up and go-to juice".
