    Dec 2013
    SW Florida
    303
    Re-tap ? fix threads so i can tighten down screws again
    Hi
    Is there any methods to redo a screw hole so that its strong again ? I have several screws that won't completely fasten. Is there any tips and tricks that some of you may employ to reinforce, such fill it with a resin and re-tap or i dunno, use a bit of plumbers tape ? (just made that up while typing this)
    Anyway, thought i'd put the question out there. As its a common occurrence for plastic screw holes to become a little worn after a few loosens and tightens.
    Jun 2016
    North Jersey
    657
    I've had decent luck pouring some CA glue in the hole and then running the screw in and letting it sit in place for a while.
    13,497
    CA or superglue are a fix. I've used plumbers tape for the pivot ball retainer screws on my Revo and they have never loosened in eight or so years. I would consider it if I stripped another hole.
    Is it common? No, unless you torque down on the threads every time you tighten them down.
    Apr 2015
    765
    I've used a dab of Shoo-Goo (E-6000) on the screw and then screw it in to the hole. That has always worked really well for me. I've never had a screw come out.
    Nov 2018
    I use the left over plastic/nylon stuff when you buy replacement parts (what's left after you twist the part off)... Shave a sliver with a razor that fits in the screw hole. The screw then holds tight!
    Indianapolis
    14,172
    I am with the other people. A little super glue on the threads of the screw you want to use will hold it together nice and tight.
