Results 1 to 10 of 10
Thread: Over usage?
    RC Qualifier Sp2deSummit's Avatar
    Feb 2019
    Yakima Washington
    376
    Over usage?
    Hey all, i am wondering if you could possibly overuse a lipo battery, like if you charge and use it too many times in one day. I know they will eventually die anyway. I am using one of the traxxas 2s 2200mAh
    any advice will help!
    I like free stuff!
    RC Champion FnFancy's Avatar
    May 2016
    Los Al California
    1,601
    I would let it rest between discharge and charging. Doesn't have to be long, what your looking for is heat. Letting the lipo rest let's it dissipate heat between cycles
    Feb 2019
    Yakima Washington
    376
    Ok, thanks! I forgot to mention, i am running it in snow right now, so would the wait be shorter then?
    Wait, never mind.
    I like free stuff!
    13,262
    A battery will have 200-500 charge cycles - depending on who you ask and the care for it. As long as you don't over-discharge, let it rest between cycles and storage charge it when sitting for longer than a day or two you'll be on the higher end.
    Feb 2019
    Yakima Washington
    376
    Thanks! So, after i run a 2s, should it be close to 7.4v when i stop? Or could i discharge it more? Or less?
    I like free stuff!
    Apr 2018
    760
    Over usage?
    If you run your Summit 1/16th in lipo mode it will automatically stop the battery from discharging too far. Once the vehicle slows, bring it in ASAP and let the battery cool off. Then recharge it or place it into storage mode as said. You donít really want to take the cells below 3.5vpc. So for a 2s lipo that would be 7v or close to that. Donít know exactly what your LVC will kick in at but if memory serves me right itís about 3.5-3.7vpc. Or 7-7.4vdc.
    13,262
    Here's where it gets confusing, maybe. A good low voltage cutoff is 3.5v/cell but Traxxas's is 3.3v or so. Storage charge is 3.8v/cell. Fully charged is 4.2v/cell.
    If the ESC is in lipo mode the truck will stop because it hit low voltage. If you try to continue to drive it the battery will become over-discharged and puff and it's life will be much shorter.
    Feb 2019
    Yakima Washington
    376
    Ok, thanks! My truck slows around 7.4v in all, or 3.7v per cell. Can i change the settings on my ESC to let it go down to about 7.2v for longer runtime?
    I like free stuff!
    May 2016
    Los Al California
    1,601
    Quote Originally Posted by Sp2deSummit View Post
    Not with the traxxas esc. Can you purchase a larger battery?
    Feb 2019
    Yakima Washington
    376
    Ok, and no, i need $ because i just dimmed my diffs and put 60k oil in them. They both took 4 shims, and i did not test to see if they would take more, because i ran out. I am planning on buying another battery eventually though (most likely a smc). one day
    They are the associated ones.
    I like free stuff!
