Results 1 to 16 of 16
    Dec 2018
    32
    Slipper Cltuch upgrade.
    So I managed to bend the slipper clutch roll pin which is making a very bad grinding noise. I know I can buy the pin for like 3 to 5 bucks but was considering upgrading the entire slipper clutch. Figured it will be less issues when I finally upgrade to brushless. What is the best choice in upgrade wise. Thank you in advance
    Sent from my SM-G955U1 using Tapatalk
    Jan 2019
    SF Bay Area
    816
    You might want to check a thread I created this morning, titled "Slipper Clutch vs Center Differential vs Center One-Way Differential". There's no definitive answer, but Squeegie did post something with two links, both of which primarily haven't to do with the F/R diffs. However, the first link (a REALLY long thread) did have several posts related to center diffs). However you look at it, the info is extremely useful.
    ~ Coming to you live, from somewhere on planet Earth.
    RC Champion Dcuda69's Avatar
    Jan 2015
    WI
    2,973
    Revo clutch. 5352R and 5351. Simple,effective and cheap.
    Slash 4x4 Ult 2150kv
    Rustler vxl
    Ford GT vxl
    Jan 2019
    SF Bay Area
    816
    Quote Originally Posted by Dcuda69 View Post
    Those are the exact same parts already used for the Rustler 4x4 & Slash 4x4. It's a slipper clutch. What I was suggesting...center differential...should be alot better.
    Jan 2015
    WI
    2,973
    Quote Originally Posted by Panther6834 View Post
    The exploded view for the Slash 4x4 shows 5556 and 5552x. The 5352R/5351 is aluminum pads which I feel make a better unit. I beat mine hard with 1/8th scale power on 3 and 4s. Thought the OP was asking about slipper clutch upgrades not center diff upgrades.
    https://traxxas.com/explodedviews/Sl...ssion-Assembly
    stock on the left, Revo on the right
    Rustler vxl
    Ford GT vxl
    Jan 2019
    SF Bay Area
    816
    First, I want just referring to the pre-installed parts of the vehicles mentioned...I was also referring to the optional parts, and, by that, the same parts area listed. If you check all these vehicles, you will find that, between the stock & optional parts, the same numbers are mentioned.
    Second, the OP did ask about upgrades to the slipper, and that could include upgrading from a slipper, to a differential. Now, if he/she is only interested in replacing the slipper with another slipper, I would recommend the Robinson Racing Slipper Unit, which comes with a 54T spur gear installed, but also has an optional 50T spur gear.
    Dec 2018
    32
    I am considering the slipper clutch only because it's a bash truck. I am still new to the hobby and not quite ready for racing just yet. I did some research and if you are going to bash the truck then stay with a slipper clutch. I do appreciate all the information on the possible options of a center diff.
    Nov 2016
    Atlanta, Georgia
    943
    +1 on the revo slipper. Upgrade has been done for years by many, simple, works, nuff said.
    Panther a little history lesson for you, the pioneers of slashes on 6s always used the revo slipper because they’d melt the stock ones all the time. It’s a simple but very effective upgrade .
    Yes center differentials may be “better” handling wise, but nowhere close to the revo slipper durability wise, which is what I believe the op is going for. You can go Robinson Racing but from personal experience steel spur gears just aren’t the wave. Plastic ones work just fine and if a rock gets stuck between it just strips the spur instead of snapping your $100 motor’s shaft. If mesh is set right you shouldn’t ever be able to strip a plastic spur unless by some sort of drivetrain lockup.
    Dec 2018
    32
    Also just seen a video on doing the revo slipper clutch upgrade/modify. Makes sense with changing the pads for a more surface area for bite.
    Here is the video I watched.
    https://youtu.be/vC3N1uY4Pfc
    Jan 2019
    SF Bay Area
    816
    This is not intended to be a "suggestion", but curiosity had got ahold of once again. What about the HR Center One-Way Diff? It's somewhat like a center diff, but I'd actually closer to a slipper. As I understand it, under acceleration & 'constant speed', it acts like a slipper, with equal & constant power to front & rear. However, during braking, as well as 'coasting', power is only to the rear wheel, as the front is effectively disengaged. Like I said, not a "suggestion", but more of an "inquiry". While I'm going to stick (for now) with the slipper in the current Rusty 4x4, the Slash 4x4 & Rusty 4x4 projects will both have center diffs.
    Nov 2016
    Atlanta, Georgia
    943
    1 way diffs are cool but I’ve never had the balls to put one in any of my rigs as I don’t have anything where I want braking limited to the rear wheels as of yet.
    Jan 2015
    WI
    2,973
    Quote Originally Posted by xXPure1n5tinctX View Post
    Some guys use a TMaxx brake disc for even more surface area. Part #4964. It requires a tick of modification to fit. I have one but have not fit it yet. Still trying to break the Revo set-up(so far unsuccessfully) lol
    Rustler vxl
    Ford GT vxl
    Sep 2015
    2,243
    I've tested with a one-way clicker (as it's usually called) for 4WD cars, the one I have for my 22-4 2.0 buggy has a normal slipper under acceleration, and a limited slip adjustable clicker to allow the front wheels to free-wheel under braking. So it basically acts like a 4WD slipper on-power, and a 2WD rear wheel off-power.
    IMO, there really is no advantage to this system, as braking is more effective on the front wheels since they load up and weight transfers to the front, so yeah I suppose if you want the rear end sliding around everytime you brake, it works, but that's almost never the fastest way around the track.
    The HR looks even worse, because I think you have a locked spool on power, so you don't even have a slipper to help manage traction/drivetrain protection.
    youtube.com/c/RazorRCvideos
    Indianapolis
    14,242
    That setup works incredibly well! I have one in my newest Ultimate edition and it works flawlessly
    Jan 2015
    WI
    2,973
    What mods did you do to fit it. Someone said they can be too thick...or something along those lines. You have it on the Revo plate...correct?
    Rustler vxl
    Ford GT vxl
    Indianapolis
    14,242
    I do. The only real mod is to enlarge the holes in the disc that mount it to the slipper plate.
