Page 2 of 2 FirstFirst 12
Results 41 to 64 of 64
  1. #41
    Nov 2018
    401
    Quote Originally Posted by MrTbone90 View Post
    I have read alot of people have issues running their rustler vxl 4x4 on 3s and breaking the stock plastic driveshafts. What has everyone found to be the better upgrade out of all the different brands to go with? I saw someone used the MIP, traxxas slash metals and they were relatively cheap. Would y'all mind send part numbers with your recommendations as well please?
    The tekno's (which are what i use) are good for racing and bashing, as long as you do not crash 50 times per bash day. If you want something really heavy duty, get the mip's. If you are just racing, get the traxxas ones. The stock plastic driveshafts do perfectly fine in the front, it is the rear ones that break. Best bang for your buck= tekno's. Overall best= MIP's. Best for racing, very light bashing, speed runs= traxxas cvds.
  2. #42
    Mar 2019
    10
    How are the GPM's?
  3. #43
    Mar 2019
    10
    Quote Originally Posted by NitroStarGT View Post
    I just bought a front set of GPM brand cvd's for the front of my Slash or Rustler. Have decided which one to put them on LOL. I believe they are the same size??
    How are the GPM's?
  4. #44
    Apr 2019
    7
    I need new ones, tekno look the way to go. Twisting the axle shaft out the fronts on 3s. Way too much torque on the stock plastic ones with the front end coming up and then down. Ripped front wheel clean off
  5. #45
    Jun 2014
    Southern California
    7,528
    If racing, get the Tekno M6s.
    If bashing, get the MIP X-Dutys.
    If not sure, get the MIPs.
    Have fun!
  6. #46
    Jan 2019
    SF Bay Area
    671
    If racing, also consider an XO-1 driveshaft conversion. Like the Tekno MY, the Traxxas XO-1 driveshafts are also 6mm.
    ~ Coming to you live, from somewhere on planet Earth.
  7. #47
    Nov 2018
    Livermore, CA
    238
    The drive shaft is a tough choice as it is. If you run 17mm wheels at all, each brand has its own set up so the 17mm hub adapter you already have? It wonít work with another brand. I have 6cars with either 6856x or 5853x adapters, if I were to get MIPS then in addition to 140 dollars for the drive shafts I need to spend another 35 on 17mm hubs. Tekno got its own thing going too with the M6ís stub axles.
  8. #48
    Jan 2019
    SF Bay Area
    671
    The great thing about going with the XO-1 conversion is that it's already running 17mm hex, so you don't don't need to use a 12mm-to-17mm conversion hex.
  9. #49
    Nov 2018
    Livermore, CA
    238
    Quote Originally Posted by Panther6834 View Post
    Is there a way to use my existing traxxas aluminum caster blocks and bearing carriers without having to buy the xo-1 parts? The rear carriers alone costs 70 dollars since they sell package of 1.5 and 3.5 degree ones one side at a time Ebay chopshops don’t have xo-1 parts very often
  10. #50
    Jan 2019
    SF Bay Area
    671
    Quote Originally Posted by TwoBelugas View Post
    The best...and only...answer I can give you is this link:
    https://traxxas.com/news/slash-4x4-driveshafts
    Although Traxxas originally put the info up for the Slash 4x4, it also applies to the Rustler 4x4, Stampede 4X4, and Rally VXL...and (possibly) any other Traxxas vehicles using the same parts as these.
  11. #51
    Jun 2014
    Southern California
    7,528
    You can use Hot Racing's 12mm to 17mm hub adapters on both Tekno and MIP CVDs.
    They come in 6mm or 10mm offsets.
    As mentioned before, the X0-1 is already 17mm and does not need an adapter.
  12. #52
    Dec 2003
    Dekalb, IL
    2,325
    I have had the same set of MIP X-Duty's on my stampede 4x4 (same as you use on the rustler I believe) for 2 years. Most of which was 2S running though, I've only been running 3S in it since September of last year. So far so good!
    Expert rigging at it's best!
  13. #53
    May 2019
    So the X-01 driveshafts fit on the rustler 4◊4?
  14. #54
    Mar 2019
    VT
    69
    Quote Originally Posted by Boren View Post
    Yes.
    https://www.youtube.com/watch?v=_jtYSPg0Q4Y
  15. #55
    Aug 2019
    I'm considering getting TKR6851X for the front and TKR6852X for the rear of my Rustler 4x4 VXL. I just want to make sure that they're going to be compatible. Can anyone confirm if they'll work?
  16. #56
    13,496
    If they fit the Slash 4x4 they will fit the Rustler 4x4. The arms, links and shafts are the same length and they use the same axle carriers/hubs.
  17. #57
    Dec 2017
    Van. Island British Columbia
    834
    Quote Originally Posted by UrickHunt101 View Post
    You could also go with the 6851A extreme heavy duty front and 6852A rear if that interests you. I just installed these on our 4x4 Stampede.
  18. #58
    13,496
    Quote Originally Posted by Rain Dawg View Post
    If I recall the Rustler already comes with the "A" version. He is referencing Tekno parts. I was confused at first but Tekno uses Traxxas's part numbers for similar products (hence the "TKR..."). Do a search online for "6851X" and you get hits on Traxxas's and Tekno's websites. Pretty smart on many accounts from a business perspective.
  19. #59
    Dec 2017
    834
    Wow that almosts seems shady lol I just installed the Traxxas ones on Wednesday and thought hey pass the info on they seem great lol. Thank you for the heads up I'll have to pay more attention.
  20. #60
    Jul 2019
    38
    MIP X-Duty are awesome. Yes they're spendy, but they're worth it.
  21. #61
    Oct 2013
    268
    I also consider to get traxxas 6851r or the MIP 10132 Front X-Duty CVD Kit.
    Itís for hard bashing with huge jumps.
    Wonder if the traxxas or the mip taking the extra beat?
    So far we have the traxxas cvd at rear and it have worked fine for two years.
    But the front do get more beat when it land bad i think...
    Price is the same for both where im order it from.
  22. #62
    RC Turnbuckle Jr. Briber's Avatar
    Dec 2015
    St. Peters, MO
    3,329
    I've used trx cvds on 2wd slash on 3s for years no problems.
    I've used mip xduties on p4de bashers on 4s-6s and in 4 years, with reg maintenance only lost barrel nut and pin once. It happens but they sell rebuild kits. Stinks they went up in price but well worth it imo.
    So my vxl on 3s im still split, use Trx cvds or give Teknos a try or else I'll steal xduties off my roller in grave yard. No ramp jumping just yard and street bashing.
    Just need one more rc, then Ill be done...
  23. #63
    Jan 2019
    SF Bay Area
    671
    Quote Originally Posted by Briber View Post
    I know the feeling, as I'm currently using the CVD (6851R & 6852R) on one of my Rusty 4x4s, as well as my Sl4sh (my other Rusty is currently running the stock drive-train, but I'm wanting to swap those, too). Right now, my first Rusty is in the final stages of a "conversion", and I've been considering swapping the CVDs for something else. I should mention that my Traxxas vehicles are all for track...albeit, not necessarily 'race' (indoor clay track, with 2S battery 'limit') use. Initially, I was considering the MIP Race Duty CVDs, but there's been a lot of somewhat-recent bad reviews on them. So, I started considering the Tekno M6 (TKR6851X for front, TKR6852X for rear), which has a larger 6mm axle. I thought I finally had it figured out...until another option came to light - the XO-1 driveshaft conversion (https://traxxas.com/news/slash-4x4-driveshafts).
    However, even more recently, I discovered some older threads in the Traxxas forum, talking about a Tekno/XO-1 'hybrid' setup:
    Tekno with XO-1
    MIP vs Tekno vs XO-1
    After reading both of these threads, this is starting to sound like a better (smarter?) possibility. The only "catch" with the hybrid setup appears to be needing to replace the stock A-arms with the Pro-Line ProTrac Suspension Kit (PRO6082-00, which I'm running on my Sl4sh, along with the Traxxas 6851R/6852R CVDs...tho, they are almost fully-extended). This is because the axles are moved out by 4mm per side (making the vehicle 8mm wider. The ProTrac kit "solves" this, by using longer A-arms, as well as SCT wheels with a different offset. This "corrects" the problem, as the included wheels have a -4mm offset.
    Unfortunately, there are two potential "downsides" (for some) to the Tekno M6/Traxxas XO-1/Pro-Line ProTrac 'hybrid' solution. The first is that you'd have to change tires, as the ProTrac wheels use SCT 2.2"/3" tires. Honestly, this is a very minor "inconvenience...I've been running SCT wheels & tires on my Rusty for a while, and they're great. The second...and slighter bigger "problem"...is that Pro_line has discontinued the ProTrac Suspension Kit for the Slash 4x4 (but, interestingly, the 2WD kit is not discontinued). Thankfully, several retailers, including AMain Hobbies, still have plenty in stock. If after reading the two hybrid' threads, this sounds like a good idea, I'd highly suggest purchasing 1-2 ProTrac kits as soon as possible...and possibly some spare ProTrac A-arms & wheels. I already have one ProTrac kit, but I'll be buying 1-2 more, plus a few wheel sets, and (maybe) even 2-4 sets of spare A-arms...just in case. I'm not trying to be a proponent of Pro-Line products, but I can say the kit contains high-quality parts, and works extremely well with Traxxas parts (tho, as mentioned above, in using the ProTrac kit with the Traxxas 6851R & 6852R, the Traxxas driveshafts are almost fully extended).
  24. #64
    Sep 2019
    16
    I just went with the Tekno for bashing.
    On 3s with MX28 and 11/54 I snap an outer stub every run.
    At least I used up all my spares
