Page 2 of 2 FirstFirst 12
Results 41 to 54 of 54
  1. #41
    Nov 2018
    401
    Quote Originally Posted by MrTbone90 View Post
    I have read alot of people have issues running their rustler vxl 4x4 on 3s and breaking the stock plastic driveshafts. What has everyone found to be the better upgrade out of all the different brands to go with? I saw someone used the MIP, traxxas slash metals and they were relatively cheap. Would y'all mind send part numbers with your recommendations as well please?
    The tekno's (which are what i use) are good for racing and bashing, as long as you do not crash 50 times per bash day. If you want something really heavy duty, get the mip's. If you are just racing, get the traxxas ones. The stock plastic driveshafts do perfectly fine in the front, it is the rear ones that break. Best bang for your buck= tekno's. Overall best= MIP's. Best for racing, very light bashing, speed runs= traxxas cvds.
  2. #42
    Mar 2019
    10
    How are the GPM's?
  3. #43
    Mar 2019
    10
    Quote Originally Posted by NitroStarGT View Post
    I just bought a front set of GPM brand cvd's for the front of my Slash or Rustler. Have decided which one to put them on LOL. I believe they are the same size??
    How are the GPM's?
  4. #44
    Apr 2019
    7
    I need new ones, tekno look the way to go. Twisting the axle shaft out the fronts on 3s. Way too much torque on the stock plastic ones with the front end coming up and then down. Ripped front wheel clean off
  5. #45
    Jun 2014
    Southern California
    7,436
    If racing, get the Tekno M6s.
    If bashing, get the MIP X-Dutys.
    If not sure, get the MIPs.
    Have fun!
  6. #46
    Jan 2019
    SF Bay Area
    486
    If racing, also consider an XO-1 driveshaft conversion. Like the Tekno MY, the Traxxas XO-1 driveshafts are also 6mm.
    ~ Coming to you live, from somewhere on planet Earth.
  7. #47
    Nov 2018
    Livermore, CA
    166
    The drive shaft is a tough choice as it is. If you run 17mm wheels at all, each brand has its own set up so the 17mm hub adapter you already have? It wont work with another brand. I have 6cars with either 6856x or 5853x adapters, if I were to get MIPS then in addition to 140 dollars for the drive shafts I need to spend another 35 on 17mm hubs. Tekno got its own thing going too with the M6s stub axles.
  8. #48
    Jan 2019
    SF Bay Area
    486
    The great thing about going with the XO-1 conversion is that it's already running 17mm hex, so you don't don't need to use a 12mm-to-17mm conversion hex.
  9. #49
    Nov 2018
    Livermore, CA
    166
    Quote Originally Posted by Panther6834 View Post
    Is there a way to use my existing traxxas aluminum caster blocks and bearing carriers without having to buy the xo-1 parts? The rear carriers alone costs 70 dollars since they sell package of 1.5 and 3.5 degree ones one side at a time Ebay chopshops don’t have xo-1 parts very often
  10. #50
    Jan 2019
    SF Bay Area
    486
    The best...and only...answer I can give you is this link:
    https://traxxas.com/news/slash-4x4-driveshafts
    Although Traxxas originally put the info up for the Slash 4x4, it also applies to the Rustler 4x4, Stampede 4X4, and Rally VXL...and (possibly) any other Traxxas vehicles using the same parts as these.
  11. #51
    Jun 2014
    Southern California
    7,436
    You can use Hot Racing's 12mm to 17mm hub adapters on both Tekno and MIP CVDs.
    They come in 6mm or 10mm offsets.
    As mentioned before, the X0-1 is already 17mm and does not need an adapter.
  12. #52
    Dec 2003
    Dekalb, IL
    2,192
    I have had the same set of MIP X-Duty's on my stampede 4x4 (same as you use on the rustler I believe) for 2 years. Most of which was 2S running though, I've only been running 3S in it since September of last year. So far so good!
    Expert rigging at it's best!
  13. #53
    May 2019
    So the X-01 driveshafts fit on the rustler 44?
  14. #54
    Mar 2019
    VT
    52
    Quote Originally Posted by Boren View Post
    Yes.
    https://www.youtube.com/watch?v=_jtYSPg0Q4Y
