Results 1 to 22 of 22
    Feb 2019
    10
    Manual Motor Gear Mesh
    Hi All,
    I'm having trouble properly meshing the gears on the X-Maxx. I'm just wondering what everyone's technique is? I put a single ply of copy paper in between the gears and put pressure against the spur then tighten the screws closest to the shaft first then the back screws. Once all done I remove the paper. But for me, it's still too tight. the gears doesn't seem to turn freely. It is also ioud when running. Am I doing it all wrong? Do I need to put a double ply? I also stripped one of the Motor mount hex screws. Are these screws not good? I stripped it on the third try trying to get it meshed properly. I didn't even use much torque. I guess they just wore out from my three attempts. I just had the X-Maxx for a week.
    Any help is greatly appreciated.
    TIA
    Apr 2018
    1,043
    Copy paper may be too thick. Use regular college rule school paper. You donít want the paper to be too thick. Then push the pinion onto the spur with the piece of paper in between as you have done before. You should be able to remove the paper without it tearing. Paper should look like an accordion when done properly.
    Feb 2019
    10
    Does it matter which screws to tighten first?
    Jun 2017
    MA
    272
    I lockdown all 4 screws while holding the motor. 2 closest to the pinion first, then verify the motor is straight, then the rear.
    Takes 2-3 tries sometimes but I want a high quality mesh.
    I use a single 3m sticky note, which is a bit thick, and I crush the gears onto it. I have yet to blow a pinion or spur.
    Quote Originally Posted by thaddyusmaximus View Post
    Aug 2015
    190
    Quote Originally Posted by Snowcrossmxz View Post
    What gears are you running??
    Jun 2017
    MA
    272
    Quote Originally Posted by gmoney82186 View Post
    Traxxas 22t pinion and the 46t that comes with the 8s in the box.
    Eastern Shore, Maryland
    4,250
    I learned a good way to adjust my truck's gear mesh from back when I use to adjust the azimuth gears on Doppler Radar antenna arrays. It works really good on my RC stuff. What you do is: you have your truck's motor mounting screws just loose enough to where you can move your motor, but tight enough that it only takes a quarter of a turn to snug them up.
    Then with you holding your motor as it gently rests on your gears, you gently run your motor. When you minimize the gear vibration you hear and feel coming from your gear mesh by moving your motor closer and further away; you snug up your screws to keep your motor temporarily in place. Then with everything stopped, you permanently tighten your motor down for final use. The paper spacing technique works good for putting you in the ball park, but the above mentioned way puts everything right on the money.
    Better to die a man, than live like a mommy part.
    15,251
    For me its trial and error. Quiet is better. Loud is bad. I don't use paper. I never had much luck with it. I check and adjust the gear lash by 'clicking' the spur and pinions teeth to get it into the ballpark. Then I fine tune by sound volume from there. I picked up a set of aluminum motor screw bushings from ebay. Makes adjusting the mesh in the field much easier.
    Ya can't polish fertilizer...
    4,250
    What's clicking?
    Dec 2001
    Everywhere man
    1,222
    All good info, and 'ticking' I think he means feeling and hearing the tiny amount of pinion/spur free play ticking.
    Feb 2013
    Andover Township, NJ
    306
    I think you are pushing/pressing to hard. Lighten up a little you'll be fine
    15,251
    What's clicking?
    Rock your spur gear back and forth, it clicks. I can get very close to perfect mesh by feeling how far the gears teeth are apart that way.
    Nov 2019
    45
    That's how I do it with my other rigs that are not Traxxas xmaxx and have had good luck so far. I'm going to try it on the xmaxx 8s now with the 46t pinion. Thanks.
    4,250
    There's a chance that you might be just a tad to late with your response. (lol)
    Nov 2019
    45
    I know right? So you do remove the pins for manual gear adjustment right? Thanks.
    4,250
    Yes, for manual gear alignment you dump the pin thing and go with a motor mount.
    Dec 2014
    Adirondacks
    651
    No need to go with a motor mount, I used my stock mount.
    4,250
    If you go the way of a Leopard motor like I did, your going to need to dump the pin thing for a motor mount. If you're stock, and you're not having any gear mesh problems, then you have a choice of using the stock pins or going to a motor mount. (IMO) if you're not having any mesh issues using a stock motor and pins, why fix something that ain't broken. Like I said, I lost having the two options when I went for a (IMO) better motor. But still...I have to say...that I am a little prejudice, because I have never been a big mesh pin fan, especially, when the mesh pins are mounted in plastic.
    Dec 2014
    Adirondacks
    651
    ...If you're stock, and you're not having any gear mesh problems, then you have a choice of using the stock pins or going to a motor mount.
    Or third option as described in the manual. Adjusting mesh manually with stock motor mount with no pins. You only need a new mount with an aftermarket motor, not with a stock motor. X-Maxx manual page 24.
    (IMO) if you're not having any mesh issues using a stock motor and pins, why fix something that ain't broken...that I am a little prejudice, because I have never been a big mesh pin fan, especially, when the mesh pins are mounted in plastic.
    Your own response gives a reason why not to use the pin system. I don't like using the pre-set gear mesh setups myself because I feel they are on the loose side. And having a bad gear mesh is the main reason why gears fail.
    4,250
    If your new motor is bigger than the stocker, then you can't use your mentioned 3rd option. Plus, my Xmaxx is the original 6s version, so it didn't take much for me to have a motor bigger than the original stock 1600kv motor. You're right, though, if you have a stock (or stock sized) motor you can adjust your mesh the pin way, or the manual way.
    Yep, I've seen that too, and agree. Plus, I like having my motor secured by a aluminum motor mount. A person doesn't have to do it that way, but I, personally, like to doing it that way. (IMO) it's the best way to go.
    Dec 2014
    Adirondacks
    651
    I agree to both! It was your wording of getting a motor mount w/stock motor that implied you needed to get one to set gear mesh manually.
    4,250
    It's nice when great minds come together in piece and harmony. (lol)
