    Feb 2019
    19
    Batería muerta porque?
    Hola grupo.
    Después de que el coche dijera que la batería había que cambiarla, yo seguí jugando 5 minutos más. Pues a la hora de poner a cargar la batería dice voltaje bajo. El de la tienda dice que ya no tiene solución que una celda está hinchada. La pregunta es? Es esto correcto? Si usas la batería un poco más de lo debido ya la batería no recupera la carga? No es una batería traxxa. Gracias
    13,279
    Quote Originally Posted by killo197 View Post
    <Google Translate>Hello group
    After the car said that the battery had to be changed, I kept playing 5 more minutes. Well at the time of putting the battery charge says low voltage. The one in the store says that there is no solution for a cell to be bloated. The question is? Is this correct? If you use the battery a little more than it should and the battery does not recover the charge? It is not a traxxa battery. Thank you
    You continued driving even after the battery was at low voltage? Then the battery puffed? This is certainly what happens when you over-discharge a battery and permanent damage occurs. This is not a battery issue but a user issue. Since it is not a Traxxas battery you best talk to the manufacturer of that battery.
    Feb 2019
    19
    Ok muchas gracias
