Results 1 to 15 of 15
Thread: X-Maxx gears
    Mar 2019
    10
    X-Maxx gears
    ok so i stripped a 18t and a 46t and am wondering if any one knows of a gear that dont brake so easy.
    Oct 2016
    4,685
    So to be tactful, Iíd lay money your gear mesh is the issue. However you can buy GDS hardened steel gears. Thatís what Iíve got. Love em.
    Mar 2019
    10
    i can find the 46t but not the 18t
    https://www.ebay.com/itm/GDS-Racing-...frcectupt=true
    Mar 2019
    10
    So to be tactful, I’d lay money your gear mesh is the issue. However you can buy GDS hardened steel gears. That’s what I’ve got. Love em.
    wait i found it...... also it was the grub screw on the 18t that came lose and then all the teeth on the 46t broke and the 18t most of them
    https://www.aliexpress.com/item/GDS-...AbTest=ae803_3
    Oct 2016
    4,685
    Quote Originally Posted by FireCat View Post
    If the shaft slipped, the gear wouldnít turn, maybe it caught in a spot and shredded the gears. Either way I got my pinions from NovaRC(formerly Kershaw), and spur is the one you shared.
    Mar 2019
    10
    i installed a 15/54 gearing just so i could drive it again..... i removed all the broken teeth before fitting had to take the truck apart used the right motor pins and testing to make sure the motor screws where tight and just drove it around and around in a circle all was working fine until i took it inside on the carpet and was just testing it back and forth about 3 meters both ways and i stripped them heard it happen they just shattered. what am i doing wrong?
    Oct 2016
    4,685
    Youíre using the pins, which is not inherently wrong. Itís a great idea with poor execution. They donít provide a proper mesh. Too much of a gap in the mesh. Remove them, check out a few videos to get the gear lash set right. You wonít have the issue again.
    Nov 2019
    49
    You’re using the pins, which is not inherently wrong. It’s a great idea with poor execution. They don’t provide a proper mesh. Too much of a gap in the mesh. Remove them, check out a few videos to get the gear lash set right. You won’t have the issue again.
    I'm about to to use 15/54t gearing on my xmaxx 8s. I don't use the pins. I'm assuming the gearing could work? I do my mesh manually.
    Mar 2016
    1,186
    15/54 came stock on the 6s Xmaxx
    fabricator
    Apr 2020
    Orange County, CA
    12
    Does anyone know where to find a GDS 18T pinion now?
    Feb 2020
    629
    Quote Originally Posted by JopRC7 View Post
    Here:
    https://www.ebay.com/sch/i.html?_fro...dkw=gds+pinion
    Mar 2016
    1,186
    Quote Originally Posted by Juanmacine View Post
    That’s 1.5mod
    Xmaxx uses 1.0mod gears
    Hot Racing
    RRP
    fabricator
    May 2020
    29
    I used these folks to send it to the UK took 5 days to arrive https://ebay.us/QsVHNx
    Feb 2020
    629
    Quote Originally Posted by CrazyXMAXX View Post
    That’s 1.5mod
    Hot Racing
    RRP
    There are 1.0mod and 1.5mod.
    Dec 2019
    Loranger, Louisiana
    16
    Robinson racing will have a great pinion. GDS and Hot racing have great spur gears.
    Sent from my moto z3 using Tapatalk
