Thread: Leaky shocks
    RC Qualifier Sp2deSummit's Avatar
    Feb 2019
    Yakima Washington
    387
    Leaky shocks
    Hey guys, I have the HR shock bodies with stock everything else, and they are leaking. HR bodies:
    The question is, how do I keep them from leaking? Do I screw the caps on really tight, or loose? Do I need new o-rings? These are the o-rings and the piston shaft:
    I noticed in the second picture there are slight scratches on the shaft. Are those causing the leakage?
    I like free stuff!
    Feb 2019
    Yakima Washington
    387
    Anybody? These things haven't had anything in them for years!
    I like free stuff!
    Feb 2019
    Yakima Washington
    387
    Would buying a new shaft solve my issue?
    I like free stuff!
    RC Qualifier zedorda's Avatar
    Sep 2015
    S.E. Michigan
    854
    I would try some teflon tape is the leak is passed threads. If it is passed the o-ring at the shaft I would replace the o-rings and inspect the shaft for linear scratches deep enough to allow leaking. If so then just buy the shock rebuild kit and a set of shafts, TiN coated if possible. But be aware these are known for leaking. I gave up and bought the GTRs.
    https://www.amazon.com/Traxxas-Hard-.../dp/B0027GGZWW
    Feb 2019
    Yakima Washington
    387
    Yeah, I think I am just gonna get the rebuild kit. Those GTRs would be real nice, but I don't have the money to spend on them. Maybe eventually I will, but I have other things I wanna get in the meantime
    I like free stuff!
